xrkiwi Member 22 Member For: 15y 1m 5d Posted 06/08/19 06:47 AM Share Posted 06/08/19 06:47 AM Hi all after quite an absence I got the bug and have bought another ute. A few issues but it had done 180k so no biggy.Previous owner had been broken into and had wrecked locks.So the had replaced only door locks and second key .One for door one for ignition. It wont lock either with key the remote or from in cabin.Door open chime is up on dash. Had a mate out today with scan tool and he can lock and unlock both doors from scan tool. However it says passenger side door is ajar. Fitted 2nd hand door assembly same thing have just fitted brand new ford lock assembly and no change.. Could it be the bcm ??no fault codes for bcm?? Thanks in advance Link to comment Share on other sites More sharing options...
mookstix New Member 14 Member For: 2y 7m 22d Posted 21/12/19 10:17 PM Share Posted 21/12/19 10:17 PM You could try recoding the key lock? Obtain a remote (can be a second hand one – they can all be reprogrammed, or you can buy a new one for about $90 from Ford). Close the doors. Turn the ignition key to the accesories position. Within 5 seconds of turning the key, hit the rear demister button (center console) three times in succession. The door locks will cycle once to indicate the special mode has been entered. Press any button on the remote you wish to program. The doors will cycle to indicate a new remote has been programmed. Continue steps 6 and 7 for all remotes (including existing ones) you intend to use on the vehicle. When you’ve programmed all the remotes, turn the ignition key off. The doors should cycle again to indicate the programming session has been completed. Link to comment Share on other sites More sharing options...
xrkiwi Member 22 Member For: 15y 1m 5d Posted 14/06/22 05:31 PM Author Share Posted 14/06/22 05:31 PM Hi Faulty BCM unfortunately previous owner and a sparky had played with wiring on door locks as well.Took a few weeks to put wiring back to stock and install new BCM Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 25,922 Member For: 14y 4m 2d Gender: Male Location: Melbourne Posted 14/06/22 10:37 PM Share Posted 14/06/22 10:37 PM Thanks for coming back to let us know, even if it was around 2 years later Link to comment Share on other sites More sharing options...
