jas98 Member 1,029 Member For: 11y 8m 25d Gender: Male Location: Maryborough Qld Posted 29/07/19 10:16 AM Share Posted 29/07/19 10:16 AM Ok. So have had this for a while (bout 10 000ks now) and doing my head in. Got a ba xr6t stock tune etc When engine gets warm like almost half way on temp guage...when cruiseing on highway at say 70kph to 100kph and gentleing accelerate the car surges while gaining speed ..kind of sounds like a missfire brrr brrr but revs dont change it still revs up fin when gaining speed. However if I give it heaps (like overtaking etc) it does surge for a couple seconds but then comes good and revs right up like nothings wrong. Went on a 2500k round trip other day...went fine besides this issue. So far I have replaced: Fuel pump Fuel reg Boost solinoid TPS Throttle body cam sensors and checked wireing Cam actuator soinoids Oil temp sensor Oil pressure senor O2 sensor Knock sensor 2 lots of coils...current ones are brand new genuine Spark plugs Also gearbox fluid lines have been by passed from radiator so no chance of coolant mixing Checked for boost leaks and also vacume leaks and could not find any. Idles perfect aswell Each time I replaced something the issue seemed to have stopped for a couple days then comes back. (Could just be me) I have not replaced crank sensor...map swnsor..or injectors ...but surely if it was injectors would do it all time?? Can a bad crank sensor only show when warm as a missfire at low rpm? Theres also no codes logged. Link to comment Share on other sites More sharing options...
Culbert New Member 2 Member For: 4y 8m Posted 18/08/19 12:11 AM Share Posted 18/08/19 12:11 AM Hi mate. Im currently having this problemwith my f6. Any info you have would be muchly appreciated. Thanks Link to comment Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 7y 8m 3d Posted 18/08/19 12:48 PM Share Posted 18/08/19 12:48 PM Does the car have any mods @jas98 is it surging or is it misfiring? Under heavy load? Up hills in 4th or 5th at slow speed heavy load? Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 22d Posted 18/08/19 07:11 PM Share Posted 18/08/19 07:11 PM Generaly with a ignition problem it will show up under load, as you accelerate you have more air/fuel between the spark plug gap, which makes it harder for the spark to jump (& fire that cyl) Usually caused by a lack of spark. You either increase the spark (new or better coils, voltage booster etc..) or decrease the distance the spark has to jump (close the plug gap- usually 0.7).spark problems with drivability are normally felt low (engine) speed/ high load . If your thinking crank angle sensor, if you can watch the tacho when the problem occurs, it reads of the sensor so if it acts crazy that will give you a indication of whats going on Link to comment Share on other sites More sharing options...
