pottypirate New Member 18 Member For: 9y 1m 16d Posted 18/07/19 10:09 PM Share Posted 18/07/19 10:09 PM Gday guys, My Ba xr6t ute is in at my mechanics at the moment getting a new transmission installed. Prior to that I just fitted a full xforce exhaust system. Its off to the tuners next ( not booked in yet) to get injectors, valve springs and a tune. Im hopping for around 300rwkw or close to and just wondering if at that power the turbo needs is it actuator work or something I read. Hi torque seem to think not but Chiptorque seem to think so. Has anyone got similar mods and what was needed only other mod is panel k&n filter Link to comment Share on other sites More sharing options...
finnas Gold Donating Members 105 Member For: 14y 3m 6d Posted 19/07/19 01:38 AM Share Posted 19/07/19 01:38 AM Stock actuator is 3 or 5psi IIRC. Generally, "rule of thumb" is actuator spring is half of max boost. I.e. 14psi Max boost. 7psi actuator. Having said that a lot of people install 12psi Actuators. But doing this means lowest commandable boost level will be 12psi. Best to see what the tuner recommends. He might be able to tune it with the stock spring to your power level. Your biggest problem might end up being the stock wastegate port. Link to comment Share on other sites More sharing options...
Head Member 74 Member For: 13y 7m 29d Posted 19/07/19 04:45 AM Share Posted 19/07/19 04:45 AM If you’ve gone the full exhaust with dump pipe and you want to achieve more boost (ie 14 psi) then you’ll need to change out your actuator and get your wastegate ported. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 19d Gender: Male Location: Adelaide Posted 19/07/19 08:03 AM Share Posted 19/07/19 08:03 AM Your intercooler and fuel pump will not go past 260rwkw comfortably The turbo rear housing will definitely need to be Ported & Flapped and at the same time definitely fit a Genuine Garret 7 psi actuator This should comfortably nail 255/260rwkw @ 11-12 psi flat Link to comment Share on other sites More sharing options...
pottypirate New Member 18 Member For: 9y 1m 16d Posted 19/07/19 07:39 PM Author Share Posted 19/07/19 07:39 PM Thanks guys. Your probably just telling me what I thought and didnt want to hear but oh well it is what it is. Booked in next monday at Real Dyno Performance in brissie for valve springs, injectors and tune but my 3200 worth of work sounds like it may be more in the range of 6500 by the time the turbo gets worked on and intercooler. Was trying to get away with minimal work as I dont drive it hard but sounds like I have a bit more work to do to make it reliable Could I get away with a hdi intercooler or not worth the money, best to just buy plszamann or process west kit? Any other cheaper coolers worth buying or do I need to just fork out the cash? Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 19d Gender: Male Location: Adelaide Posted 20/07/19 12:48 AM Share Posted 20/07/19 12:48 AM On the B series the HDI cooler kit is cheap and works ok for low 300’s its a bit of a pig to install vs say the Plazmaman 800hp kit for the B series which basically bolts in it’s just the way it is now days with the older platform as the Valve springs will probably want to stop all the fun as you get close to the 300rwkw mark anyway The fuel pump on the B series is all out of flow at around the 260rwkw mark also Sometimes you just have to tick one off at a time and get it all tuned to suit The last BF I did was a F6 Typhoon and managed to nail 290rwkw with a ZF auto and around 11 psi on 98 fuel Walbro intank 255 Valve springs Full exhaust port and Flapper modification Garrett 7 psi actuator Stock F6 intercooler Air box modification KPM 1000cc injectors New coils Major service Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 23d Posted 20/07/19 01:09 AM Share Posted 20/07/19 01:09 AM Ignor this bloke's advice at your own peril 1 Link to comment Share on other sites More sharing options...
pottypirate New Member 18 Member For: 9y 1m 16d Posted 20/07/19 07:38 PM Author Share Posted 20/07/19 07:38 PM Okay cheers. Looks like ive gotta dig a little deeper into the pockets for reliable power in the range im after. Fuel pump turbo work and cooler it is then. Link to comment Share on other sites More sharing options...
