ERICtheBERIC Member 105 Member For: 9y 7m 14d Gender: Male Location: Perth Posted 15/07/19 01:39 PM Share Posted 15/07/19 01:39 PM So im finally starting the engine build for my BA xr6t sedan now that the tax dollars have come in. I bought an FG n/a motor a few months back with the intention of stripping it and doing the basic mods before swapping it into the car with the stock BA turbo and the rest of the running gear (sump, ECU, plenums, etc) . The mods I have planned are as follows: valve springs (purchased) billet oil pump gears maybe FG turbo exhaust valves depending on price injectors fuel pump intercooler (already purchased a nizpro core) turbo side intake with crossover delete, 12 psi actuator mild exhaust with high flow cat tune The aim is to achieve around 500 whp and have the car as my daily and do a bit of circuit work on weekends. Ive read that some people prefer to use the FG egas motor for a turbo conversion, my question is whether its worthwhile for me to buy an egas motor for my application as they can be sourced quite cheaply. And could somebody possibly explain to me what the differences between the FG petrol and egas motors actually are as ive read some conflicting information. Cheers guys Link to comment Share on other sites More sharing options...
nathanway Member 106 Member For: 12y 8m 12d Gender: Male Location: townsville Posted 28/07/19 01:29 AM Share Posted 28/07/19 01:29 AM the fg gas motor green top is the better option for your build the na motor has weak rods and will begin to be unreliable at the 500hp mark especially on 98 the gas motor has very high compression for a turbo motor but its pretty common to see 400kws on 98 on e85 more power can be made the price difference between a na and the gas motor is only a couple hundred bux so id say it worth it you should also try and get a fg turbo intake manifold Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 23d Posted 28/07/19 07:45 AM Share Posted 28/07/19 07:45 AM The main difference is pistons, rods and exhaust valves. Why not put something decent while your nearly there? Dont forget to sort the dipstick out before you put the BA sump back on Link to comment Share on other sites More sharing options...
