G6EEEETTTT Member 27 Member For: 5y 7m 30d Posted 15/07/19 12:34 AM Share Posted 15/07/19 12:34 AM Looking to do some upgrades to my G6E Turbo. First stage will be cat, injectors and tune. Second stage will be intercooler. Looking to get the max out of the stock FG turbo, but might upgrade to a bigger turbo further down the track and push up towards 380 rwkw. Maybe. Might be happy with around 320 rwkw with the stock turbo though. But when buying parts I'd like to buy stuff that could work with a bigger turbo if I go down that path. Looking at these 2 cats. I'd assume the first one comes with the dump pipe off the back of the turbo and the 2nd one doesn't? And for the power levels I'm looking at is the dump pipe needed? Or will the second one do the job? https://www.ebay.com.au/itm/VENOM-FG-FGX-TURBO-4-DUMP-PIPE-CAT-Ford-FG-XR6-Turbo-F6-Ford-FPV-Exhaust/262162954198?epid=27026720081&hash=item3d0a2137d6:g:FzIAAOSwa81XSqXe https://www.ebay.com.au/itm/Venom-Ford-FG-FGX-XR6-Turbo-F6-High-Flow-Cat-Pipe-Catalytic-Converter-Exhaust/261549503557?hash=item3ce590b445:g:Nu8AAOSwfC9XPVw- Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 15/07/19 03:14 AM Share Posted 15/07/19 03:14 AM any exhaust part (dump onwards) will fit to whatever turbo you choose as when you upgrade the turbo you generally don't upgrade the rear housing that the dump connects to (especially for anything below 500rwkw), so both of those will work totally fine and it just depends on how much you want to spend and if you want extra turbo exhaust noise. The cat only will do the job for your goal power. Link to comment Share on other sites More sharing options...
G6EEEETTTT Member 27 Member For: 5y 7m 30d Posted 15/07/19 04:10 AM Author Share Posted 15/07/19 04:10 AM 54 minutes ago, k31th said: any exhaust part (dump onwards) will fit to whatever turbo you choose as when you upgrade the turbo you generally don't upgrade the rear housing that the dump connects to (especially for anything below 500rwkw), so both of those will work totally fine and it just depends on how much you want to spend and if you want extra turbo exhaust noise. The cat only will do the job for your goal power. Cheers. So the standard dump would still be fine even if I wanted to go a bit bigger in turbo size? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 15/07/19 04:27 AM Share Posted 15/07/19 04:27 AM yep, as long as you keep the stock turbocharger exhaust housing then it's still fine up to power you would probably not bother to aim for 1 Link to comment Share on other sites More sharing options...
