What Offset on BF ute
J4ck
  • New Member
  • Member For: 4y 8m 28d
Hey, I was looking at getting some new rims for my 2007 BF turbo ute and wanted something wide on the rear to handle all 660hp, not sure what would fit, was thinking something like an 18x10.5 on the rear and 18x9.5 on the front, but not sure what offset or if I need to roll the guards
  • less WHY; more WOT
  • Site Developer
  • Member For: 15y 11m 19d
:Welcome2FordXR6t:
well, honestly you don't want to be going wider rims in the hope of handling all of your power (490kw is a stout figure if that's what you're running) as no wider standard street tyres are going to really help a lot at the high 400rwkw mark. If your sole goal is traction rather than rims, then sticky tyres is the way to go; semi-slicks on the rear.
if you want rims, too, then your options are limited severely if you specifically want 9.5's on the front...
  • New Member
Not to worried about the fronts 8.5's would be fine I just wanted the bigger rims on the rear but I'm not sure if I should go 10.5s on the rear or 9.5s if so what offset and do I need and do I to roll the guards at all
