Joel0201 Member 26 Member For: 5y 12d Posted 08/06/19 11:53 PM Share Posted 08/06/19 11:53 PM Hey guys I’ve doing some work in my project car, it’s a bf turbo. Now here’s what happen, I was driving went to hit the brakes and hardly anything happen the pedal went to the floor it locked the rear up al little..... but his the wired part the pedal was locked to the floor keeping the brakes stuck on..... even if we moved a 1m forward would release so I used my hand to lift the pedal up and they started to work again. that left me thinking I had a booster issue, I check the lines and pressure coming out of it both good. How ever when feeling the pressure coming into the booster I noticed it built up with the revs but when the bov went off it had some blow back I’m not sure if that affecting it. So I’m wondering if anyone has insite into this am I right thinking I need a new booster like one of the diaphragms inside could be stuffed. Thank you Link to comment Share on other sites More sharing options...
Joel0201 Member 26 Member For: 5y 12d Posted 13/06/19 09:30 PM Author Share Posted 13/06/19 09:30 PM update ( doing service and gonna replace all the rotors all round and pads) going to buy a booster/master too does anyone know if na and turbo ones are the same? (Mines a xr6 bf turbo 2006) Link to comment Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 11y 2m 28d Gender: Not Telling Posted 14/06/19 12:40 AM Share Posted 14/06/19 12:40 AM (edited) hmmm booster in my experience goes hard or holds the brakes on slightly. Before throwing money at it, a brake shop can test a booster for you: I took one down to get rebuilt, they tested it on the spot and handed it back- the issue was a vacuum leak in that vehicle. Edited 14/06/19 12:42 AM by skidxr6t Link to comment Share on other sites More sharing options...
Joel0201 Member 26 Member For: 5y 12d Posted 15/06/19 11:13 AM Author Share Posted 15/06/19 11:13 AM Ok sweet mate sounds like a plan thank you, I’ll look into it thank you Link to comment Share on other sites More sharing options...
