Kiwi1989 New Member 13 Member For: 4y 11m 8d Posted 20/04/19 09:25 AM Share Posted 20/04/19 09:25 AM Hello there. I need some help. I have a ba xr6 turbo with some mods done. I have the turbosmart wastegate. Now my mechanic has told me that my car is overboosting. The wastegate is starting to open when im at 20psi. Which he tells me this can cause major problems. Why could this be and how can it be fixed? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,239 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 20/04/19 09:37 AM Share Posted 20/04/19 09:37 AM What mods? 20psi is wayyyyyyyyyyy too much for a stock BA XR6T. Link to comment Share on other sites More sharing options...
Kiwi1989 New Member 13 Member For: 4y 11m 8d Posted 20/04/19 09:40 AM Author Share Posted 20/04/19 09:40 AM Injectors air intake flash tune valve springs fuel pump exhaust nothalane diff bushes mechanic is taking waste gate off atm to adjust boost level... My mechanical knowledge isnt that great with these types of things. Just want to boost changed and lowered so its safe. Link to comment Share on other sites More sharing options...
tazzanz Donating Members 573 Member For: 8y 7m 26d Gender: Male Location: NZ Posted 20/04/19 09:46 AM Share Posted 20/04/19 09:46 AM Do not drive it on boost if its boosting 20psi. Is it the turbosmart internal wastegate or external? Link to comment Share on other sites More sharing options...
Kiwi1989 New Member 13 Member For: 4y 11m 8d Posted 20/04/19 09:48 AM Author Share Posted 20/04/19 09:48 AM Pretty sure its internal. Sits off the turbo. Can you adjust the boost levels through the wastegate? And how is it fixed fo get it back under control? Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 10m 27d Gender: Male Location: Western Sydney Posted 20/04/19 10:03 AM Share Posted 20/04/19 10:03 AM Adjust the preload. If that doesn't drop it enough change the spring to a lower rated one.Chances are it's a 12psi unit which has a 5 and 7 psi spring in it. Link to comment Share on other sites More sharing options...
Kiwi1989 New Member 13 Member For: 4y 11m 8d Posted 20/04/19 10:09 AM Author Share Posted 20/04/19 10:09 AM Ok thank you. Whats the pre load? And how do you adjust it? thanks Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 10m 27d Gender: Male Location: Western Sydney Posted 20/04/19 10:17 AM Share Posted 20/04/19 10:17 AM Leave it for your mechanic. 1 Link to comment Share on other sites More sharing options...
Kiwi1989 New Member 13 Member For: 4y 11m 8d Posted 20/04/19 10:20 AM Author Share Posted 20/04/19 10:20 AM Ok thank you. is it an expensive to do it? Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 10y 8m 27d Gender: Male Posted 20/04/19 12:33 PM Share Posted 20/04/19 12:33 PM You haven't actually tuned this to handle the mods, have you.... Link to comment Share on other sites More sharing options...
