Joel0201 Member 26 Member For: 5y 12d Posted 14/04/19 06:38 AM Share Posted 14/04/19 06:38 AM Hey guys I have a bf turbo with a zf I am swapping over the box as it’s faulty I know the basics like remove starter undoing of converter ect I was wondering if there is a how to for removal/install just for a bit of help/guildline if there’s not I will take pictures along the way when I do mine. thanks Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 9m 26d Gender: Male Location: Adelaide Posted 14/04/19 06:53 AM Share Posted 14/04/19 06:53 AM (edited) Removing the starter motor and undoing coverter bolts from the starter motor hole is the hardest part, the rest is easy typical bell housing bolts and rear trans mount bolts from the sub floor, remove shifter link and heat exchanger then tailshaft out and away she goes mate Edited 14/04/19 06:54 AM by JETURBO 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,044 Member For: 9y 1m 27d Gender: Male Location: South Australia Posted 14/04/19 06:56 AM Share Posted 14/04/19 06:56 AM Removing an auto box has been the same for the past 70+ years. The only extra bit is the wiring loom. Here's a starter removal tip; use some creative visualisation and socket extensions to reach the top fastener. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 14/04/19 06:57 AM Share Posted 14/04/19 06:57 AM helps to remove the exhaust from the cat to rear muffler, too. 2 Link to comment Share on other sites More sharing options...
Joel0201 Member 26 Member For: 5y 12d Posted 14/04/19 11:29 PM Author Share Posted 14/04/19 11:29 PM Ok thank you very helpful Link to comment Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 13y 2m 19d Gender: Male Posted 03/08/19 09:43 AM Share Posted 03/08/19 09:43 AM Can it be done on ramps or do u need a hoist for clearance? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 03/08/19 09:59 AM Share Posted 03/08/19 09:59 AM jack up both ends of the car and there's room... can't imagine there'd be enough room on just ramps, but it could slide out the front once it's lowered, I guess. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 9m 26d Gender: Male Location: Adelaide Posted 03/08/19 10:06 AM Share Posted 03/08/19 10:06 AM It’s a tall box mate and ramps only might not cut it, this has been an issue with other cars when I was much younger and not having a hoist to use maybe some big HD tall ramps will do it Link to comment Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 13y 2m 19d Gender: Male Posted 03/08/19 11:46 AM Share Posted 03/08/19 11:46 AM What about quickjacks, they go to 447 mm? Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 9m 26d Gender: Male Location: Adelaide Posted 03/08/19 11:58 AM Share Posted 03/08/19 11:58 AM Yeh that should get you there 1 Link to comment Share on other sites More sharing options...
