Joe2601 New Member 5 Member For: 4y 11m 18d Posted 10/04/19 09:29 AM Share Posted 10/04/19 09:29 AM Hi advice on getting some new tyres Guards rolled and I have room to move on my 2009 Falcon FG XR6 Currently the 20 inch rims have 225/35 R20 on them (bought from friend) and before I go buy tyres I am thinking I want to go wider in the back if so what size would I get Do I go same all round or can I go wider in rear? Link to comment Share on other sites More sharing options...
cat007 Member 234 Member For: 5y 6m 24d Posted 10/04/19 09:32 AM Share Posted 10/04/19 09:32 AM How long is a piece of string.Depends on their offset as well as overall width.I'm running 245/35R20 on my FGX on an 8 inch rim and they could with 255 or maybe even 265. Link to comment Share on other sites More sharing options...
Joe2601 New Member 5 Member For: 4y 11m 18d Posted 10/04/19 09:50 AM Author Share Posted 10/04/19 09:50 AM (edited) Im happy to stay with the 225/35R20 on the front but do I stay with the same /35 prfile on rear if I go wider so if I go 255 rear do I need to compensate with the profile? offset if ET 36 on originals 17's and ET 36 on new rims Edited 10/04/19 09:53 AM by Joe2601 Link to comment Share on other sites More sharing options...
xr6666turbo Donating Members 102 Member For: 6y 9m 20d Gender: Male Location: Brisbane Posted 10/04/19 10:00 AM Share Posted 10/04/19 10:00 AM I have 20's on my BF ute. Fronts are 8.5 +20. I have recently put on Michelin 265 30 Pilot Sports. Great tyres, no dramas. Guards untouched. Tight fit but I have Shockworks coilovers so it's just a matter of adjusting the height to get clearance for turning. Rears are 10 +25. Running Nitto 295 35 r20. Guard work needed for these as I needed 8mm spacers to clear the Brembos. Without the spaces you probably wouldn't need to touch the guards but it would be a tight fit. Link to comment Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 7y 7m 13d Posted 10/04/19 10:09 AM Share Posted 10/04/19 10:09 AM 17 minutes ago, Joe2601 said: Im happy to stay with the 225/35R20 on the front but do I stay with the same /35 prfile on rear if I go wider so if I go 255 rear do I need to compensate with the profile? offset if ET 36 on originals 17's and ET 36 on new rims How wide are the rear rims? Link to comment Share on other sites More sharing options...
Joe2601 New Member 5 Member For: 4y 11m 18d Posted 10/04/19 10:13 AM Author Share Posted 10/04/19 10:13 AM Rims are all the same 20x8.5J I suppose I answered my own question. If the rims are all the same size then do I need to go all the same with tyres? Link to comment Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 7y 7m 13d Posted 10/04/19 10:35 AM Share Posted 10/04/19 10:35 AM No you can go bigger on the rear. Maximum size would be 255 on a 8.5” rim Link to comment Share on other sites More sharing options...
scotto14 Member 2 Member For: 11y 8d Posted 10/04/19 10:47 AM Share Posted 10/04/19 10:47 AM P Link to comment Share on other sites More sharing options...
Joe2601 New Member 5 Member For: 4y 11m 18d Posted 10/04/19 10:50 AM Author Share Posted 10/04/19 10:50 AM (edited) Ok so I read somewhere I can go 245/35 R20 on the front if I put on a 5mm spacer. If I go 255 on the back would I stick with 35 profile or something else? "On the front it's the upper control arm that is the worry with 20" rims on a FG with a 35 offset. A few have done it but have had to go a 235 tyre. Unless you fit a 5mm spacer then you can go a 245. And don't forget if you want it to turn in, you will want some neg camber. On the rear you can go a 275 on a 9 1/2" rim with a 38 offset no worries. That will sit right with the guards. And yeah there is no lip so all good." Edited 10/04/19 10:55 AM by Joe2601 Link to comment Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 7y 7m 13d Posted 10/04/19 11:30 AM Share Posted 10/04/19 11:30 AM from front to back there will be about 3mm difference in height, so you would want to stay at a 35 profile. Remember the profile is the % of tyre width so that's where the extra height comes from. if you go a 255/30 you will have a 10mm smaller side wall in the rear compared to the front and the rolling diameter will be about 20mm less also Link to comment Share on other sites More sharing options...
