sd1800 Member 51 Member For: 13y 2m 17d Posted 07/04/19 10:15 PM Share Posted 07/04/19 10:15 PM (edited) Hi Guys, hoping you can help me diagnose a noise coming from my driveline that has been getting progressively more noticeable over the last 3 months or so. I have included a video below. Listen for the wobble-board type sound when accelerating in 1st gear between about 1000-2000rpm. It only really does it when accelerating away from low speed or a standstill, and you can't replicate the noise in any other scenario outside of that. In the video below, I've kept the clutch fully engaged the whole time to demonstrate that it isn't a noise that occurs when the clutch is being slipped from a standstill. And it sounds like it's originating from the driveline (not the engine bay). I'm leaning towards the doughnut or centre bearing, but a quick visual inspection under the car showed they appeared to be OK (but I'm not 100% what I'm looking for either!). Keen to hear your thoughts before I take it to a shop! Edited 07/04/19 11:51 PM by k31th fixed video Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,240 Member For: 15y 11m 19d Gender: Male Location: Melbourne Posted 07/04/19 11:54 PM Share Posted 07/04/19 11:54 PM only when it's on slow speed... hmmm engine mounts? is the engine moving around a lot when you rev it when it's sitting still? the sound itself sounds like the turbocharger exhaust vanes hitting the inside of the exhaust housing, but that would be happening at any speed. Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 10y 8m 27d Gender: Male Posted 08/04/19 01:08 AM Share Posted 08/04/19 01:08 AM 1 hour ago, k31th said: the sound itself sounds like the turbocharger exhaust vanes hitting the inside of the exhaust housing, but that would be happening at any speed. Could still be that maybe until a little bit of boost built up? Either way, doesn't sound so great. I'd get it on a hoist sooner than later Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 12y 3m 27d Gender: Male Location: WA, Perth Posted 09/04/19 05:27 AM Share Posted 09/04/19 05:27 AM it could be that the gear stick is loose under the boot cover. Check the bolts that hold the gear lever to the shifter. Lever removed: I changed my gear lever from the stock one to a Hurst lever and I get to hear all the wonderful noises that the manual gearbox makes. Hurst lever installed Link to comment Share on other sites More sharing options...
sd1800 Member 51 Member For: 13y 2m 17d Posted 11/04/19 07:37 AM Author Share Posted 11/04/19 07:37 AM Thanks for the feedback guys.Interesting about the noise coming from the turbo. I tend to think it won't be it as I can't get it to replicate the noise under any other low / mid / high boost scenario in any other gear or neutral.I checked engine mounts the other day by loading it up in gear with the handbrake on and bonnet up. Very minimal movement so it won't be that. Also interestingly is the noise doesn't occur when I did this, so leads me to have think it's a driveshaft rotation-under-load issue rather than clutch/flywheel. Also checked the gear stick mounting and it's totally A-OK. Thanks for that suggestion though!I can see I've got a small split on my centre diff bush. Will be replacing that soon with super pro. Maybe that's causing it, or is a flow on effect (unusual angle on the centre bearing when taking off due to tailshaft dropping down due to shagged centre bush?)Speaking of centre bearing, for years now I have read very conflicting stories about whether FG MK2 bearings are replaceable, or if the tailshaft is just one single unit. Is there a definitive thread on this subject? Link to comment Share on other sites More sharing options...
sd1800 Member 51 Member For: 13y 2m 17d Posted 14/04/19 01:56 AM Author Share Posted 14/04/19 01:56 AM Got under the car today to have a look at the uni and the centre bearing. Does this look like a normal amount of movement? Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 12y 3m 27d Gender: Male Location: WA, Perth Posted 15/04/19 03:23 AM Share Posted 15/04/19 03:23 AM @k31th and @FiftyOne, does that look right. I am almost sure that is not meant to be like that. Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 10y 8m 27d Gender: Male Posted 15/04/19 06:33 AM Share Posted 15/04/19 06:33 AM 100% not the person to be asking on the matter. But if I see correctly, the rubber has sagged and is cracked around the top. I would be changing it anyway as a wearing item Link to comment Share on other sites More sharing options...
