bupalooga Silver Donating Members 255 Member For: 11y 6m 18d Gender: Male Location: Griffith NSW Posted 03/04/19 07:53 AM Share Posted 03/04/19 07:53 AM So I'm a little bit devastated to have uncover this to say the least and at the worst possible time. Was cleaning the Interior for the first time this year and noticed the paint bubbles and rust bleeding through the sill. A couple minutes with angry pliers uncovers a rusty cavern about 5mm deep but it would easily double in size and get deeper if I kept picking at it. Also rust patches along the door seam under the door rubber. It's been a few warm dry days since opening it up but there's still moisture in the hole and I'm too scared to keep digging. Is a professional autopsy and reconstructive surgery my only real option. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,302 Member For: 16y 14d Gender: Male Location: Melbourne Posted 03/04/19 08:20 AM Share Posted 03/04/19 08:20 AM yeah, looks like you'll have to sand it back, cut it out, put in a new piece of metal with the right shape and then prepare/prime and re-paint. Link to comment Share on other sites More sharing options...
My_XR6_Turbo Member 282 Member For: 19y 8m 22d Posted 03/04/19 09:05 AM Share Posted 03/04/19 09:05 AM (edited) Wow I have never seen that before. As k31th said grind, cut, replace, weld, prime, paint. I wonder what caused it. What's the other side like? Have you looked under the doors for rust? Edited 03/04/19 09:05 AM by My_XR6_Turbo Wrong name Link to comment Share on other sites More sharing options...
bupalooga Silver Donating Members 255 Member For: 11y 6m 18d Gender: Male Location: Griffith NSW Posted 03/04/19 09:29 AM Author Share Posted 03/04/19 09:29 AM Can't say I wasn't expecting to hear that but I was really hoping for otherwise. The drivers side is perfect, just the passenger side. The door seems to be fine aswell, just the sill. Does anyone know how the structure is manufactured under there? Maybe it's been scooping water from under the car into a crevice or something? Maybe water was getting in behind the door seal and funnelling to the bottom, seaping between the sheets of steel. I'll try stick my head around this weekend and get a closer look at everything.I'll just make a mess trying to patch it myself and it's my only mode of transport so I think I'll need to see a pro. Link to comment Share on other sites More sharing options...
bupalooga Silver Donating Members 255 Member For: 11y 6m 18d Gender: Male Location: Griffith NSW Posted 29/01/20 06:18 AM Author Share Posted 29/01/20 06:18 AM Update.I eventually got the rust looked at and my god was it far worse than expected. And the believed culprit... This grommet that wasn't plugged in, most likely from yanking the wiring 4yrs ago while pulling the indicators out. Was getting welded back up today and should be getting painted next week. He took a heap of photos so I'll post some when I get em. 2 Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 9m 3d Posted 29/01/20 09:31 AM Share Posted 29/01/20 09:31 AM Falcons are legit pieces of sh*t. I have rust in front a pillar, and all through the boot area, and some suspect spots around the fire wall that I don't want to go looking for. 1 Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 11m 23d Gender: Male Location: Western Sydney Posted 29/01/20 09:54 AM Share Posted 29/01/20 09:54 AM Fact lolThe mob I work for has an FG Ute. Its shocking around the door sills.Still a good thing to see before mine cops it. Link to comment Share on other sites More sharing options...
santb01 Inactive Members 1 Member For: 15y 7m 11d Posted 10/03/20 10:58 PM Share Posted 10/03/20 10:58 PM On 29/01/2020 at 4:18 PM, bupalooga said: Update. I eventually got the rust looked at and my god was it far worse than expected. And the believed culprit... This grommet that wasn't plugged in, most likely from yanking the wiring 4yrs ago while pulling the indicators out. Was getting welded back up today and should be getting painted next week. He took a heap of photos so I'll post some when I get em. Do you have those extra pics? Have identical problem in my 2010 ute. My passenger-side pillar was FULL of water. I pushed my finger through the vertical face of the pillar (easily) when discovering bubbles; I reckon 3-500mls of water fell out. Everyone's been scratching their heads. Doesn't appear to be anywhere water can get in. Now I know there is, so thanks. The most promising idea so far has been a/c leak/condensation through firewall, which I'm pretty sure isn't physically possible. Am planning an a/c leak test just to be sure anyway.. Does water from exterior flow straight over that grommet from windscreen/whatever? Or across? Wouldn't take a big leak to fill up like that over time. But a waterfall flowing straight into the top of the grommet every time it rains... Was there any indication of deeper structural damage ie chassis or firewall? Typical Ford. The cost of a cable tie to secure the cable might've saved some stress and $$ on repairs.. What was the repair cost, if you don't mind saying..? Thanks for any help. Was starting to think I was gonna have to sell it for whatever I could get just to be rid of it. Link to comment Share on other sites More sharing options...
bupalooga Silver Donating Members 255 Member For: 11y 6m 18d Gender: Male Location: Griffith NSW Posted 11/03/20 11:26 AM Author Share Posted 11/03/20 11:26 AM Ill Chase the pics up off the guy, I think he should be back in town. The A/C typically drips onto the carpet from the center when its drain is blocked, not near the door sills. Directly above the grommet (just out of photo) there's a drain that comes from the windscreen. The guy tested with the grommet in & out and water was definitely pouring straight in that way. You can take the quarter panel off or unclip the plastic wheel arch lining and stick your head in there to see if the grommet has popped out or not. Total repairs and paint was around $2500 Cut out both the outer layer (pictured) and the middle layer or steel. The back layer was cleaned up and sealed before replacement outer & middle panels were welded back into place. Link to comment Share on other sites More sharing options...
bupalooga Silver Donating Members 255 Member For: 11y 6m 18d Gender: Male Location: Griffith NSW Posted 08/08/20 12:43 PM Author Share Posted 08/08/20 12:43 PM Finally remembered to chase up these photos. 2 1 Link to comment Share on other sites More sharing options...
