K4L4M1TY Member 32 Member For: 5y 1m 26d Posted 26/03/19 01:19 AM Share Posted 26/03/19 01:19 AM Hi guys, been having an overboost problem with my stock bf xr6t, so I got my air compressor out and ran about 5-7psi through the actuator and it didnt budge, went up to about 15psi and it moves out somewhat not sure if it was fully open but then looks like it closes again but possibly not all the way. I'm guessing it's forked? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 26/03/19 01:30 AM Share Posted 26/03/19 01:30 AM yeah, that is either a much stronger wastegate than a stock one or it's cactus... Link to comment Share on other sites More sharing options...
K4L4M1TY Member 32 Member For: 5y 1m 26d Posted 26/03/19 05:49 AM Author Share Posted 26/03/19 05:49 AM (edited) Thanks mate, I assume it should stay open to where it goes to under constant pressure too, as mine opens then returns to closed straight away basically as if there is a hole and it gets enough pressure to move it then leaks through even though I was still putting air into it. I'm guessing the diaphram or the hose itself is leaking air. Bought some new vacuum line today as a last hope before replacing actuator. Looking at one of the turbosmart 7psi ones but not sure if it would be ok with even that slight raise in boost(6psi is stock from what I've researched). Edited 26/03/19 05:52 AM by K4L4M1TY Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 26/03/19 05:53 AM Share Posted 26/03/19 05:53 AM yep, it should stay open under constant pressure and should seal the wastegate port completely when there's no pressure. yeah, the stock one is about 5-6psi and a turbosmart 7psi one with the correct pre-load can work OK, but ideally would require a run-up on a dyno to be sure it's not spiking boost with the current setup. Link to comment Share on other sites More sharing options...
K4L4M1TY Member 32 Member For: 5y 1m 26d Posted 29/04/19 05:02 AM Author Share Posted 29/04/19 05:02 AM Thanks mate, well I got mine off with turbo still in place, read that I should not be able to blow through the actuator at all with my mouth but I can, I guess that means the diaphragm is dead yes? Been told that MTQ should have or be able to get me a new oem actuator so I'm going to do that. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 29/04/19 05:19 AM Share Posted 29/04/19 05:19 AM yeah, does sound like the actuator diaphragm is dead. 1 Link to comment Share on other sites More sharing options...
BeerTurbo Donating Members 234 Member For: 5y 11m 11d Posted 29/04/19 08:03 AM Share Posted 29/04/19 08:03 AM 2 hours ago, K4L4M1TY said: Thanks mate, well I got mine off with turbo still in place, read that I should not be able to blow through the actuator at all with my mouth but I can, I guess that means the diaphragm is dead yes? Been told that MTQ should have or be able to get me a new oem actuator so I'm going to do that. Yep sounds cactus. you blowing a diaphragm that seals in the drum, against a spring.... you should be met with 100 percent resistance when blowing into it. most turbo places should be able to get a stock ford sprigged actuator. as an idea : https://gcg.com.au/petrol-performance/performance-4/wastegates-accessories-internal/wastegate-actuator-ford-xr6-ba-bf-fg-standard-5psi-detail if you plan on modifying the car later a turbo smart wastegate may be a decent option, however if you install it with the 7 psi spring the car may freak out...altho the falcon runs closed and open loop boost control so it may actually be able to handle that small difference. it would most defiantly have a sad with the 14psi spring and no tune however. Link to comment Share on other sites More sharing options...
K4L4M1TY Member 32 Member For: 5y 1m 26d Posted 29/04/19 10:52 AM Author Share Posted 29/04/19 10:52 AM Thanks mate, got one tee'd up to pick up tomorrow and gotta find me some dump studs. I do plan on mods down the track but I want this car back on the road as I just bought it and regoed etc, for the price of it I just want it reliable for now and thinking I'll end up going external gate and whatnot eventually. I was looking at the turbosmart ones but been told they aren't quite right in terms of running on a stock motor/tune and I really don't want to have to spend any more on the motor right now as I've also got some dang diff bushes to get replaced and dont think I'll have the necessary equipment to do that myself. Thanks for your help and advice fellas and hopefully it all goes back together and runs fine after that. Link to comment Share on other sites More sharing options...
K4L4M1TY Member 32 Member For: 5y 1m 26d Posted 04/05/19 09:53 AM Author Share Posted 04/05/19 09:53 AM Thanks for all your help guys, new actuator installed and all seems to be running fine now. Next step, upgrades👍 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 04/05/19 10:01 AM Share Posted 04/05/19 10:01 AM Well done successful fixes are what we live for haha 1 Link to comment Share on other sites More sharing options...
