ken666 Donating Members 140 Member For: 5y 3m 23d Posted 25/03/19 08:27 PM Share Posted 25/03/19 08:27 PM I'm in the process of building a new turbo for a friend to replace his worn out factory unit, but when we removed the worn out turbo to use the original turbine housing to use on the new setup we put together. I noticed that most of the bolt holes (dump pipe side) are almost stripped out. The new parts are a billet AR .70 compressor housing, with anti-surge 4" inlet, a new Garret GT3582 dual ball bearing cartridge with a billet wheel fitted. But now we will have to replace the rear turbine housing due to the problems with the threads being so worn, unless drilling and fitting helicoils is a viable option? If not, a new housing will be sourced. I have read a few articles about changing the AR size to a smaller volume to help the turbo spool quicker, but I don't have much experience with turbos. I would assume that by doing this, it would restrict flow at higher RPM (and possibly create more heatsoak through the turbo?) Has anyone experimented with fitting smaller AR.63 or AR.82 housings. Obviously the wastegate will still be ported to 38mm on the housing to be fitted. Any help would be greatly appreciated, Cheers ken Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 14d Gender: Male Location: Melbourne Posted 25/03/19 09:58 PM Share Posted 25/03/19 09:58 PM A smaller exhaust housing isn't the best idea for a 4L motor, but will work reasonably OK for moderate power levels, and as you suggested, it does restrict flow and creates extra waste heat. The 0.7 front cover will introduce lag, too. You can try to get the threads repaired, if they're not reaching the torque required, but yeah, otherwise it needs replacing. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 24d Gender: Male Location: Adelaide Posted 25/03/19 09:59 PM Share Posted 25/03/19 09:59 PM Hi Ken the factory fitted 1.06 5 bolt T3 rear housing is a perfect match for a 60+ front wheel with a cover of 0.5-0.7 imho and it’s not much to be gained as the already snappy FG spec turbo is on boost almost instantly with a automatic transmission something to consider is the fact if you deviate away from factory specs youll need a custom tune to suit so that 0.7 front cover you have selected will already require a tune to suit rear housings have been an interesting point over the years and expensive at that but I’ve got a new unit that I’ve had a small part in getting made up with constant R&D from myself and if you want I could supply you with one ready to bolt on to any factory CHRA and comes with all required gaskets and seals to do the changeover. Hit me up for one via PM this is what it looks like and full factory specs but a better desinged port and chamber with a big 39mm flapper 1 Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 2m 12d Gender: Male Location: SW Sydney Posted 26/03/19 02:40 AM Share Posted 26/03/19 02:40 AM ^Have heard good things about these Link to comment Share on other sites More sharing options...
