Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 19/03/19 09:14 AM Share Posted 19/03/19 09:14 AM 39 minutes ago, Duane343 said: Stuck in the sticks Which ones? Link to comment Share on other sites More sharing options...
Duane343 New Member 14 Member For: 8y 8m 24d Posted 02/04/19 03:47 AM Author Share Posted 02/04/19 03:47 AM Just an update guys. I had a mechanic have a look and it is definitely the return spring that needs to be replaced. I called ford and they said they can only sell me the entire pedal assembly for about 550. All I need is that 1 part. I tried a wrecker and he said about 250 and he reckons no one will want to sell just that part only the whole pedal assembly. I will keep looking, but I was hoping someone on here might have an old one that they might be willing to part with for a bit cheaper. Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 11m 23d Gender: Male Location: Western Sydney Posted 02/04/19 07:17 PM Share Posted 02/04/19 07:17 PM Pretty sure you can just use a spring.From memory someone here had a valve spring modded to fit and repair theirs. 1 Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 2m 13d Gender: Male Location: SW Sydney Posted 02/04/19 07:40 PM Share Posted 02/04/19 07:40 PM @Duane343 voila.... 1 Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 12y 4m 25d Gender: Male Location: WA, Perth Posted 04/04/19 12:28 AM Share Posted 04/04/19 12:28 AM Sorry I am late to the show. Camo, spot on mate. It is the spring that has snapped. Happened to mine. Not an easy job if you don't have the tools. It is a valve spring that is in my car right now. However you will need a die grinder to flatten an edge up a bit and grind the internal part of it to allow it to fit in said place. The alternative is to pay $280 for the pedal set which includes the spring. Good luck @Duane343 Link to comment Share on other sites More sharing options...
clevo400 Member 32 Member For: 13y 3m 2d Gender: Male Location: Townsville Posted 17/08/20 05:00 PM Share Posted 17/08/20 05:00 PM Hey Guys, I too have had the Clutch Return Spring snap and cut my right leg. It's a BA2 Turbo with the T56. The Clutch Pedal was always heavy with the Standard Ford Clutch and after the Xtreme HD Clutch was installed it was just as heavy then it just snapped. In the morning the Pedal is slightly depressed and after a few pumps it seems to come back to normal height. Can you let me know what Valve Spring you used as I thought it had a hook end but if it is a flat end even better. Thanks. Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 12y 4m 25d Gender: Male Location: WA, Perth Posted 21/11/20 06:17 AM Share Posted 21/11/20 06:17 AM @clevo400, I haven't been on for a while, so late to the party again. The FG valve spring was used. I believe that the hook would have been removed or cleaned up with a die grinder. I did not do the work. Mechanic did it for me. Link to comment Share on other sites More sharing options...
