Duane343 New Member 14 Member For: 8y 8m 18d Posted 19/03/19 05:40 AM Share Posted 19/03/19 05:40 AM Hey guys, I've been having a few problems with my clutch. I have a FG xr6t 2011. I was hoping that someone here would be able to help me figure out what the problem is. I'm stuck out in the sticks at the moment, I've hurt my back real bad and I can't work some money is tight. Basically when I release the clutch pedal it makes a loud click noise. I got down and pressed it in with my hand and I could see where the noise is coming from and it is from around the spring part that returns the clutch pedal after taking your foot off the pedal. I'm hoping its is an easy fix that I can do myself. Thanks! I have a photo of the part that's making the sound but I am trying to figure out how to insert photo? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 8d Gender: Male Location: Melbourne Posted 19/03/19 05:42 AM Share Posted 19/03/19 05:42 AM here's the instructions for posting the pictures -> https://www.fordxr6turbo.com/forum/topic/92470-how-to-put-images-in-your-post/ so your problem is only a "clicking" sound? Link to comment Share on other sites More sharing options...
Duane343 New Member 14 Member For: 8y 8m 18d Posted 19/03/19 05:45 AM Author Share Posted 19/03/19 05:45 AM It's a very loud click, it started out as intermittent and now its every time. Ok Thanks Keith I will get that photo up Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 8d Gender: Male Location: Melbourne Posted 19/03/19 05:49 AM Share Posted 19/03/19 05:49 AM ok, it's probably the return spring on the pedal just moving about a bit, but that's only a guess. Link to comment Share on other sites More sharing options...
Duane343 New Member 14 Member For: 8y 8m 18d Posted 19/03/19 05:57 AM Author Share Posted 19/03/19 05:57 AM Yeah actually Keith you can see it move or jump a bit when it makes that noise. Here's the return spring Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 8d Gender: Male Location: Melbourne Posted 19/03/19 06:02 AM Share Posted 19/03/19 06:02 AM hmm, you might need to lever the spring (or the bit of metal itself) away from that bit of metal that it's pushing on, to prevent it from jumping around, as it should move smoothly Link to comment Share on other sites More sharing options...
Duane343 New Member 14 Member For: 8y 8m 18d Posted 19/03/19 06:18 AM Author Share Posted 19/03/19 06:18 AM Ah I will give it a try thanks. I dont think its actually the spring itself but rather the part of the assembly. I'm pretty sure it's the little black piece at the back that kind of slides horizontally and "Clack". Its pretty hard to see in there. Thanks again for your help Keith. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 8d Gender: Male Location: Melbourne Posted 19/03/19 06:25 AM Share Posted 19/03/19 06:25 AM no worries Link to comment Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 7y 8m 4d Posted 19/03/19 07:46 AM Share Posted 19/03/19 07:46 AM 1 hour ago, Duane343 said: Yeah actually Keith you can see it move or jump a bit when it makes that noise. Here's the return spring looks broken. see the plastic at the top side of the spring (black part) could just be angle too though 1 Link to comment Share on other sites More sharing options...
Duane343 New Member 14 Member For: 8y 8m 18d Posted 19/03/19 08:33 AM Author Share Posted 19/03/19 08:33 AM I can see a crack in that bit of white plastic, That black part is metal. It has a little bolt on the side that can turn and I assume a little rod through the middle of it. I'm going to take it to the mechanics soon but money is tight at the moment and I always like to know what is broken before getting it fixed. Stuck in the sticks as well so I got to go a different guy I've never been to before. Link to comment Share on other sites More sharing options...
