ibby-kunis New Member 1 Member For: 5y 10m 19d Posted 04/03/19 09:21 AM Share Posted 04/03/19 09:21 AM Hi guys, so I’ve had a light accident in my xr6 turbo, basically the only damaged was a cracked front bar so I got a new one and changed it, and my airbags went off in the accident. The panel beater put a new front tie bar that sits behind the front bar, and I put new airbags in the driver steering wheel and passenger side, and I left the fuse out incase it goes off again. So my airbag light was on when the fuse was in (before I took it out), what else needs to be changed so I can get rid of the airbag light? Link to comment Share on other sites More sharing options...
EGO747 New Member 4 Member For: 7y 4m 14d Posted 04/03/19 10:54 AM Share Posted 04/03/19 10:54 AM Possibly: Check if the pretensioners have been fired, the RCM (under dash - must be correct type (A,B,C), crash sensor near the bonnet catch may also need to be changed. Link to comment Share on other sites More sharing options...
ImTheCobra New Member 5 Member For: 10y 4m 21d Posted 17/11/19 10:39 AM Share Posted 17/11/19 10:39 AM On 04/03/2019 at 7:51 PM, ibby-kunis said: Hi guys, so I’ve had a light accident in my xr6 turbo, basically the only damaged was a cracked front bar so I got a new one and changed it, and my airbags went off in the accident. The panel beater put a new front tie bar that sits behind the front bar, and I put new airbags in the driver steering wheel and passenger side, and I left the fuse out incase it goes off again. So my airbag light was on when the fuse was in (before I took it out), what else needs to be changed so I can get rid of the airbag light? Airbag module brother! 1 Link to comment Share on other sites More sharing options...
