Jumbuck Member 25 Member For: 5y 2m 15d Gender: Male Location: Melbourne Posted 23/02/19 05:53 AM Share Posted 23/02/19 05:53 AM FG-X Turbo. I am about to order a Brembo 6/4 kit - and wheels also. Before I order the wheels, I want to ensure they will fit over the brakes. The wheels are 19" Work Emotion Kiwami. Has anyone fitted these before? If not, could someone help me out with the following measurements? Thanks Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 11m 22d Gender: Male Location: Western Sydney Posted 23/02/19 07:12 AM Share Posted 23/02/19 07:12 AM If I can fit 18" rotas with 6/4 brembos I'd be confident work 19s would do it easy.If no one else helps out pm me and I'll measure them up when I get home tomorrow arvo. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,298 Member For: 16y 13d Gender: Male Location: Melbourne Posted 23/02/19 09:08 AM Share Posted 23/02/19 09:08 AM the only way if you know it'll 100% clear brembo's is to actually do the measurements on your vehicle (or test-fit to a brembo fitted vehicle or know of somebody who has this wheel and brake combo you're looking for), imho. Link to comment Share on other sites More sharing options...
Jumbuck Member 25 Member For: 5y 2m 15d Gender: Male Location: Melbourne Posted 23/02/19 11:15 AM Author Share Posted 23/02/19 11:15 AM Ok thanks for the hand. And yes - good advice Keith Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 11m 22d Gender: Male Location: Western Sydney Posted 24/02/19 06:53 AM Share Posted 24/02/19 06:53 AM If anyone else needs the info.Took the measures with a tape measure and a straight edge on the measured part so it may be off slightly.Front A) 45B) 115C) 75D) 195K) 30L)5M) 120-125RearA) 35B) 115C) 160D) 185K) 30L) NA (square edged)M) 105 1 Link to comment Share on other sites More sharing options...
dubfreer01 Member 2 Member For: 11y 6m 7d Posted 24/10/23 04:07 AM Share Posted 24/10/23 04:07 AM Hey Jumbuck, Did you end up trying this combination? If so what specs were the rims? I've got 6/4's at home (not fitted yet, going on fgx turbo) and would like to put on a set of Kiwami's. Link to comment Share on other sites More sharing options...
Jumbuck Member 25 Member For: 5y 2m 15d Gender: Male Location: Melbourne Posted 24/10/23 05:43 AM Author Share Posted 24/10/23 05:43 AM Good Afternoon @dubfreer01 Thanks for tagging me. Haven't visited in years but happy to contribute. The wheel specifications were as follows REAR WORK EMOTION CR2P 5-114.3 BLK 19 X 10.0 +55 R-DISK, GLOSS BLACK CENTER DISK, GLOSS BLACK ANODIZED LIP - FLAT RIM NOTE: I had a rear link kit from SuperPro which allowed the 10 inch rim on the rear FRONT WORK EMOTION CR2P 5-114.3 BLK19 X 8.5 +35 R-DISK, GLOSS BLACK CENTER DISK, GLOSS BLACK ANODIZED LIP - FLAT RIM FINDINGS 1. At those offsets there was plenty of room between the rim and the brakes (front rims would have looked better with less offset and closer to guards) 2. At those front offsets Pirelli PZero PZ4 didnt fit as PZ4 has a wide sidewall which hit the suspension on the inner section. Pirelli PZero did fit 3. At those rear offsets and with SuperPro rear link kit fitted a Mickey Thompson 285 Street ET was a perfect fit (also little loss of traction even in first gear WOT [at 460rwkw] if tyre pressure is < 30ish PSI) 4. Given there was plenty of room between the rim and the brakes a deeper concave may have been achievable which would have looked ALOT better (flat concave is not ideal - try and get at least a semi concave as they look fantastic on the CR2P) - Use Leonardo who JDM concepts to your advantage - he is knowledgeable on what will fit 5. Dont gutter rash the rims - I did 1 - takes several months to order/arrive/fix I no longer have the XR6T. Now I have an XR8SPRINT 6. Consider acquiring XR Sprint Rims - they look fantastic, good quality, fit under the brakes... not quite as light as the work rims though Hope that helps James Link to comment Share on other sites More sharing options...
dubfreer01 Member 2 Member For: 11y 6m 7d Posted 24/10/23 09:26 PM Share Posted 24/10/23 09:26 PM @Jumbuck Thanks for the reply, that's really good info. Link to comment Share on other sites More sharing options...
