mikeutu
03 ba falcon xr6 fuel tank leak
hi there
after some information please.
03 ba falcon xr6.
car was driven over some rocks not sure how big I wasn't there, there is a dent in the fuel tank steel cover directly below the fuel sender on the underneath. from near empty putting fuel in at around the 25-30ltr mark there's a leak not small either. have looked while it's leaking but can't seem to see bugger all. so have removed the sender and checked seal area for obvious damage and no obvious. jacked up rear end and removed the fuel lines and sheet steel cover. and tried removing the tank only to find out through old mate Google can't be done without removing IRS, rear subframe and diff FFS!. does anyone have any ideas on what to check before I dismantle the whole rear end to change the tank out 😢
thanks in advance
Share this post
Link to post
If you wasn't there, how do you know what happened. I think this thread and you should disappear, only one reason. And that reason is, your full of sh*t.
Share this post
Link to post
tanks probably cracked, they occasionally do this even without damaging them.
remove rear seat and check around the pump area for leaks/smell.
Edited by skidxr6t
Share this post
Link to post
    No registered users viewing this page.
  • Donation Box
    Please donate to support the community.
    We appreciate all donations!
FordXR6Turbo.com Powered by Invision Community
