Torqjunkie New Member 2 Member For: 5y 3m 14d Posted 09/01/19 11:27 AM Share Posted 09/01/19 11:27 AM Hi there, im new here so sorry if this has been discussed before ... But can it be done?No im not buying a already turbo'ed barra coz I cant find one in RSA ... im left with only option and that's to do the 190 wich is essentially the same engine as the barra 245T except for pistons etc. Has someone done this before end what power figures did they achieve? Planning an e46 swap Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 25d Gender: Male Location: South Australia Posted 09/01/19 11:50 AM Share Posted 09/01/19 11:50 AM Yes you can do it, you can do anything. Stalk this guy => @NA_TURBO Not that I've tried, but you probably wouldn't want to make more than 300rwkw on a na petrol motor. 1 Link to comment Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 8y 6m 15d Gender: Male Location: Mildura Posted 09/01/19 12:07 PM Share Posted 09/01/19 12:07 PM Yes can be done. Cheaper to buy a turbo engine/setup and swap it over. Pistons and rods won't hold much power.You'll need oil lines plus fittings for the oil pressure sensor, water lines for the turbo, manifold, injectors, fuel pressure regulator, oil drain needs to be drilled and tapped into sump, one way valve for the pcv system, butterflies removed from intake manifold, new fuel pump, 2 bar map sensor needs to be fitted and wiring modified to suit. Valve springs need to be done too as they don't like boost, exhaust valves are different material too, ecu needs to be retuned and mapped to suit.Power steering cooler is in the way of the intercooler when you go to fit it. Link to comment Share on other sites More sharing options...
Torqjunkie New Member 2 Member For: 5y 3m 14d Posted 09/01/19 12:45 PM Author Share Posted 09/01/19 12:45 PM Aint the rods the same after may 2006? Also I can get the NA for basically $900 wereas the 245t that came in the terry is round about $3500 and that's if I can find one, and that one isnt blown up... so for the $2600 I save I can do a few things... wouldve changed turbo,mani,and valvesprings anyway... im doing the conversion(or want to) in a e46 bmw Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,302 Member For: 16y 14d Gender: Male Location: Melbourne Posted 09/01/19 12:49 PM Share Posted 09/01/19 12:49 PM it's 06/06, e.g. June 2006, but that's for the XR6T to get the same tougher motor as the equivalent Typhoon, in B-series form. and yeah, just get a barra block, then a barra head and change everything for more power 1 Link to comment Share on other sites More sharing options...
