ken666 Donating Members 140 Member For: 5y 3m 23d Posted 01/01/19 05:48 AM Share Posted 01/01/19 05:48 AM Hi, I was wondering if anyone has attempted to replace the diff cover on a BA XR6T, without dropping the cradle? I only had the cradle and all out of the car 2 weeks ago to replace the bushes and diff, but it appears that there must have been a fault or hairline crack in the alloy where the bolt goes in..... and it broke a piece off the top, and now the bolt just swings in the breeze! Is this a common issue, or could it just be the result of the extra play when the bush was flogged out? Cheers Ken Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 14d Gender: Male Location: Melbourne Posted 01/01/19 05:53 AM Share Posted 01/01/19 05:53 AM probably just extra play from when it was flogged out. nah, you can't replace the diff cover without dropping the cradle, unfortunately. Link to comment Share on other sites More sharing options...
ken666 Donating Members 140 Member For: 5y 3m 23d Posted 01/01/19 06:19 AM Author Share Posted 01/01/19 06:19 AM If I have to pull it all out again, I should learn a bit more about what parts I have to use to cope with the power and torque going through them. My car is producing 612hp at the treads, and has destroyed 2 bushes since I got it 2 months ago..... The first was a rubber OEM type with the shell, so I fitted a solid blue urethane one, but it quickly broke free of the alloy tube its bonded to and was forced out of the tube on the cradle and over the head of the bolt? (I have fitted a 45mm washer/retainer to hopefully resolve this issue with the latest bush) I replaced it with a nolathane unit with the relief holes in it, hoping that they will absorb some of the load. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 14d Gender: Male Location: Melbourne Posted 01/01/19 07:01 AM Share Posted 01/01/19 07:01 AM well, if you make it solid, they it just transfers the load to the bolt and housing... it needs some holes and a bit of softness to actually absorb the forces through it. while it's apart the second time, get the IMS twin-bush kit put in, to avoid further diff bush/bolt/housing problems. Link to comment Share on other sites More sharing options...
ken666 Donating Members 140 Member For: 5y 3m 23d Posted 01/01/19 07:55 AM Author Share Posted 01/01/19 07:55 AM that's a much better design than the original. I will be building a new diff with lower gears to compensate for the turbo lag and the new cams I'm fitting in march, I will definitely fit a kit at the same time. As the car is my daily driver, I wouldn't receive the parts before I return to work on the weekend. But I do have a spare cradle and diff assy that I will prepare ready to swap out. Thanks for that tip Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 14d Gender: Male Location: Melbourne Posted 01/01/19 08:23 AM Share Posted 01/01/19 08:23 AM no worries, mate. happy to help 1 Link to comment Share on other sites More sharing options...
