Legnets98 New Member 1 Member For: 5y 4m 3d Posted 20/12/18 01:49 PM Share Posted 20/12/18 01:49 PM I'm looking to do a build with a engine out side of my car so I can continue to drive mine on the daily looking to get 800+hp besides the obvious Bolt on turbo is there a whole lot of difference between the n/a engine compared to the turbo am I better off modding up a factory turbo engine, looking to build it pretty much from the bottom up Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,302 Member For: 16y 14d Gender: Male Location: Melbourne Posted 20/12/18 01:54 PM Share Posted 20/12/18 01:54 PM If you're going to be building the engine anyway, you may as well just get an N/A engine as it's cheap, then chuck in the relevant quality bits you want for the desired power level, as the "block" itself is the same. Then all you need to do is get a turbo sump (or modify the N/A one to suit the oil pump and turbo oil drain) and get the valve springs and valves from a turbo engine for the head. 1 Link to comment Share on other sites More sharing options...
