maso92 New Member 1 Member For: 5y 3m 22d Posted 06/12/18 06:29 AM Share Posted 06/12/18 06:29 AM Hey I Brought A Futura With A XR6 Turbo Motor Converted Into It. Drives Fine But It When It Goes Into Boost It Feels Like It Starts Going Into Boost Then Stops And Shudders Like Traction Controls Is On Or Something And Don't Feel Like Boost Is Even On Any Ideas On What's Happening And There Are A Few Vacuum Lines I Don't Know Where They Go Will Add Pics Link to comment Share on other sites More sharing options...
Billy New Member 1 Member For: 5y 3m 19d Posted 09/12/18 03:40 AM Share Posted 09/12/18 03:40 AM Hey mate, not the most experienced person with the Barra but generally speaking you should find where all those vacuum lines go because they all serve a purpose. I had the same issue when I bought my ba xr6t and every time I fixed a loose connection it ran better, smoother. Also not sure if this is frowned upon but it worked for me when I removed the boost solenoid next to the battery and sprayed wd40 into the vacuum lines. Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,013 Member For: 8y 11m 6d Gender: Male Location: Canberra ACT Posted 09/12/18 11:13 AM Share Posted 09/12/18 11:13 AM 1. Scan for fault codes as a starting point.2. Check your coils and plugs. There's an excellent chance it is coils and a new genuine set will sort you out. Link to comment Share on other sites More sharing options...
