Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 25/11/18 06:24 AM Share Posted 25/11/18 06:24 AM No worries. Link to comment Share on other sites More sharing options...
Slowxr6t Member 515 Member For: 5y 4m 16d Location: New zealand Posted 16/01/19 10:41 AM Share Posted 16/01/19 10:41 AM So puff, on the xr6t do you need a bleed valve to run more boost than the actuator? Or can the tuner alter boost through the ecu? How does it work? Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 10y 9m 18d Gender: Male Posted 16/01/19 10:47 AM Share Posted 16/01/19 10:47 AM Don't mess around with piggy back boost controllers & bleed valves. It's old technology & these aren't hack skylines from the 90's. The factory computer doesn't like to be fooled, get it tuned properly. The falcon computer regulates boost via the wastegate with a solenoid in a closed loop system. The only way to do it safely is to tune it. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 16/01/19 10:47 AM Share Posted 16/01/19 10:47 AM 5 minutes ago, Slowxr6t said: So puff, on the xr6t do you need a bleed valve to run more boost than the actuator? Or can the tuner alter boost through the ecu? How does it work? My missus just got home from work mate so I'll get back to you later. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 16/01/19 11:17 AM Share Posted 16/01/19 11:17 AM 23 minutes ago, Slowxr6t said: So puff, on the xr6t do you need a bleed valve to run more boost than the actuator? Or can the tuner alter boost through the ecu? How does it work? There are things you can do with a bleed valve that will work perfectly fine (that mostly still involve tuning) but for the most part you will just want to tune it properly. 19 minutes ago, FiftyOne said: The falcon computer regulates boost via the wastegate with a solenoid in a closed loop system. It uses open and closed loop fyi, not that it's a major omission. 28 minutes ago, Slowxr6t said: How does it work? Here's some links bro then I'm heading off for some missus time. https://forum.pcmtec.com/index.php?/topic/15-howto-boost-control-babf/ https://forum.pcmtec.com/index.php?/topic/74-howto-open-loop-boost-control-fg/ Post number four courtesy of @molch https://forum.hptuners.com/showthread.php?64860-Tuning-n00b&p=484960&viewfull=1#post484960 Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 10y 9m 18d Gender: Male Posted 16/01/19 11:42 AM Share Posted 16/01/19 11:42 AM You are correct there actually Puff. However I've seen a lot of nice cars ruined with bleed valves & boost controllers, just sayn Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 16/01/19 12:01 PM Share Posted 16/01/19 12:01 PM Yeah it's something you can do but it's not usually the best approach. Doing things properly and safely is best practice. 1 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 24d Gender: Male Location: Perth Posted 17/01/19 03:18 AM Share Posted 17/01/19 03:18 AM 15 hours ago, FiftyOne said: You are correct there actually Puff. However I've seen a lot of nice cars ruined with bleed valves & boost controllers, just sayn Yep. Puff ruined his. Piston and rods say NO. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 17/01/19 03:25 AM Share Posted 17/01/19 03:25 AM How did I ruin it lol? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 24d Gender: Male Location: Perth Posted 17/01/19 03:29 AM Share Posted 17/01/19 03:29 AM Can you go out now and take it for a drive??? Link to comment Share on other sites More sharing options...
