Mitch666 New Member 3 Member For: 5y 6m 1d Posted 21/11/18 03:44 PM Share Posted 21/11/18 03:44 PM Seeing If anyone has installed a Walbro 460 into they’re bf xr6t, if so did they use the stock wiring? Have seen some people wire a relay in using the original power as the switch and running 6mm wire straight off the battery as the new main power? Don’t see how it wouldn’t work but would have to play around with the original plug tomake it work as it is a part of the fuel sender unit? Link to comment Share on other sites More sharing options...
