arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 23d Gender: Male Location: Perth Posted 27/07/19 01:22 AM Share Posted 27/07/19 01:22 AM Jut get the ones I listed from ford. Max $10 - $12 each. These are cheaper. same PLUG. https://www.ebay.com.au/itm/GENUINE-FORD-BF-FG-FALCON-EGAS-LPG-SPARK-PLUG-SET-0-7mm-PRE-GAPPED-AGSP22YE07/121506938920?epid=6023982705&hash=item1c4a60c028:g:nQkAAOSwofxUf7tS&frcectupt=true Link to comment Share on other sites More sharing options...
Slowxr6t Member 515 Member For: 5y 4m 15d Location: New zealand Posted 27/07/19 02:10 AM Share Posted 27/07/19 02:10 AM So the YE07's are 1 colder than stock? You say you've used lots of them, how long do they last aaronm? Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 2m 7d Gender: Male Location: SW Sydney Posted 27/07/19 02:24 AM Share Posted 27/07/19 02:24 AM No they're the same heat range (22) as standard turbo plugs, only the gap differs (0.7 vs 1.1) Genuine FG turbo plug: https://www.ebay.com.au/itm/6-x-Genuine-Ford-Spark-Plugs-Falcon-FG-Turbo-EcoLPI-Iridium-AGSP22YE11-DENSO-/201130729311 The plugs arronm linked are from FG gas motor which as @JETURBO stated are fine @ ≤500rwkw I also use these Don't overthink it 1 Link to comment Share on other sites More sharing options...
Slowxr6t Member 515 Member For: 5y 4m 15d Location: New zealand Posted 27/07/19 08:52 AM Share Posted 27/07/19 08:52 AM Ok thanks camo. So why is it not necessary to go to colder plugs with these motors when usually turbo motors need to? Link to comment Share on other sites More sharing options...
HOTXR6T Donating Members 58 Member For: 5y 9m Gender: Male Location: SA Posted 28/07/19 09:52 AM Share Posted 28/07/19 09:52 AM On 27/07/2019 at 10:57 AM, arronm said: No, what plugs are you using? I buy these which are 20 heat range 22 is slightly colder, but when you open the packet the plug inside is AGSP22YE07’s. Used multiple sets but only noticed last time I installed a set. https://www.ebay.com.au/itm/GENUINE-FORD-BA-BF-FALCON-SPARK-PLUG-SET-SK20R7-TO-SUIT-EGAS-LPG-ANTI-BACKFIRE/290628022377?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Hi the link is for BA-BF Are FG the same plug? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 23d Gender: Male Location: Perth Posted 28/07/19 09:55 AM Share Posted 28/07/19 09:55 AM Yes... 1 Link to comment Share on other sites More sharing options...
HOTXR6T Donating Members 58 Member For: 5y 9m Gender: Male Location: SA Posted 28/07/19 10:32 AM Share Posted 28/07/19 10:32 AM What would be the best coils? I am thinking genuine ford as well, or is there some thing better, for a FG XR6T Running 350 RWKW Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 2m 7d Gender: Male Location: SW Sydney Posted 28/07/19 10:35 AM Share Posted 28/07/19 10:35 AM Genuine first, daylight second Link to comment Share on other sites More sharing options...
HOTXR6T Donating Members 58 Member For: 5y 9m Gender: Male Location: SA Posted 28/07/19 10:40 AM Share Posted 28/07/19 10:40 AM Thanks I thought so, but better to check before buying. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 23d Gender: Male Location: Perth Posted 28/07/19 11:34 AM Share Posted 28/07/19 11:34 AM https://www.ebay.com.au/itm/GENUINE-FORD-FG-FGX-FALCON-2008-2017-4-0-6-SPARK-PLUG-IGNITION-COILS-COIL-SET/301497223927?hash=item4632a28af7:g:HJwAAOSw0KdctqxF&frcectupt=true 1 Link to comment Share on other sites More sharing options...
