Jordan83 New Member 7 Member For: 5y 8m 4d Gender: Male Location: Wellington, New Zealand Posted 15/11/18 12:48 AM Share Posted 15/11/18 12:48 AM Hi All, I am just wanting suggestions on plugs and gap settings? The car is 401rwkw. Cheers Link to comment Share on other sites More sharing options...
finnas Gold Donating Members 105 Member For: 14y 3m 6d Posted 15/11/18 02:36 AM Share Posted 15/11/18 02:36 AM stock factory ford plugs gapped to 0.8mm Link to comment Share on other sites More sharing options...
Jordan83 New Member 7 Member For: 5y 8m 4d Gender: Male Location: Wellington, New Zealand Posted 15/11/18 03:04 AM Author Share Posted 15/11/18 03:04 AM Cheers, will this give me that balance between cruising and under load? The problem has been a missfire at cruising speeds.. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 8d Gender: Male Location: Melbourne Posted 15/11/18 03:30 AM Share Posted 15/11/18 03:30 AM sounds like your tuner needs to clean up the cruising part of your tune... it should not misfire on cruise as there's almost always no boost. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 18d Gender: Male Location: Adelaide Posted 15/11/18 08:09 AM Share Posted 15/11/18 08:09 AM AGSP22YE07’s , don’t gap plugs when you can buy Genuine ford plugs at 0.7mm gap Perfect for stock-500rwkw @ 22 psi sounds like you tuner needs to scale injectors better “IF” your plugs/coils/02 sensor are all good Link to comment Share on other sites More sharing options...
Slowxr6t Member 515 Member For: 5y 4m 14d Location: New zealand Posted 27/07/19 12:48 AM Share Posted 27/07/19 12:48 AM @JETURBO, Hi, are you saying the standard xr6 turbo sparkplug which is 6 heat range is fine for up to 22psi boost? Im going to run 18psi and about 350rwkw and I thought 1 heat range colder would be needed. Is it not necessary to go to colder plugs on these motors??? Thanks Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 2m 6d Gender: Male Location: SW Sydney Posted 27/07/19 12:51 AM Share Posted 27/07/19 12:51 AM What jet quoted is the gas motor plug, not the turbo plug arronm do your link thang.... Link to comment Share on other sites More sharing options...
Slowxr6t Member 515 Member For: 5y 4m 14d Location: New zealand Posted 27/07/19 12:55 AM Share Posted 27/07/19 12:55 AM Thanks camo, so should I go 1 colder heat range to a 7? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 22d Gender: Male Location: Perth Posted 27/07/19 12:57 AM Share Posted 27/07/19 12:57 AM No, what plugs are you using? I buy these which are 20 heat range 22 is slightly colder, but when you open the packet the plug inside is AGSP22YE07’s. Used multiple sets but only noticed last time I installed a set. https://www.ebay.com.au/itm/GENUINE-FORD-BA-BF-FALCON-SPARK-PLUG-SET-SK20R7-TO-SUIT-EGAS-LPG-ANTI-BACKFIRE/290628022377?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Link to comment Share on other sites More sharing options...
Slowxr6t Member 515 Member For: 5y 4m 14d Location: New zealand Posted 27/07/19 01:18 AM Share Posted 27/07/19 01:18 AM I have stock standard plugs in it at moment, iv just been stock piling parts and I'm about to start the big monster garage project soon, Ford over here said they cant get 1 heat range colder, repco said $56 per plug for 1 heat range colder iridium, but that sounds way too much $. No one in nz seems very helpful so far. Link to comment Share on other sites More sharing options...
