joffa1 Member 143 Member For: 6y 9m 13d Posted 12/11/18 06:43 AM Share Posted 12/11/18 06:43 AM Hi guys quick one have Factory 19 inch rims on my FG XR6T Ute, running Kumho 245/35/R19s on front wheels destroyed one of my rear tyres the other day but both rear were pretty low on tread anyway so going to replace rears (still plenty of tread on the fronts). My question is is can I run a wider and slightly higher profile tyre on the rears? have a good deal on some Hankooks 275/40/R19s so basically just want to know if it’s ok to have a 40 profile on the rear and a 35 on the fronts and if I can go this wide also? thanks for any advice! Link to comment Share on other sites More sharing options...
joffa1 Member 143 Member For: 6y 9m 13d Posted 12/11/18 07:39 AM Author Share Posted 12/11/18 07:39 AM Or someone just recommend me some good rear tyres given I have 19 inch factory rims and 235/45/19s on the front? cheers. Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 2m 13d Gender: Male Location: SW Sydney Posted 12/11/18 08:32 AM Share Posted 12/11/18 08:32 AM Your posts are contradictory, do you have 245/35 or 235/45 on the front? Big difference in rolling diameter Link to comment Share on other sites More sharing options...
joffa1 Member 143 Member For: 6y 9m 13d Posted 12/11/18 09:25 AM Author Share Posted 12/11/18 09:25 AM Sorry my bad! 245/35 on the fronts I guess I’m hoping to go wider for more grip and a higher profile to smooth out the ride a little if that helps? with a view to going a higher profile up front once they wear out too. Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 2m 13d Gender: Male Location: SW Sydney Posted 12/11/18 05:52 PM Share Posted 12/11/18 05:52 PM (edited) You don't want to be running 275/40/19 up the back then, rears will be nearly 50mm bigger diameter. Plenty of conflicting info out there you can google, but I wouldn't be using tyres more than say 2% difference in diameter front/rear. 275 is way too wide for the factory rims anyway which if I remember correctly are only 8.0" - 245 is max 'recommended' width for an 8" rim, you could probably go to a 255 without too many dramas.... @arronm?? Best way to 'smooth out your ride' would be to go to an 18" wheel but probably not what you want to do. Jump on http://willtheyfit.com and play around with your options, personally I'd be sticking with the 245/35 (or go to a 255 if it fits ok - some tyre brands are wider/narrower than others even size for size) or go 245/40 all round, or get different (ie. wider) rims and run wider tyres. Check out http://tyresales.com.au and https://tyres.supercheapauto.com.au or your local tyre guy and see what's out there, read reviews, use the search bar on here and make your decision. Edited 12/11/18 05:57 PM by camo86T Link to comment Share on other sites More sharing options...
joffa1 Member 143 Member For: 6y 9m 13d Posted 12/11/18 06:57 PM Author Share Posted 12/11/18 06:57 PM Great help. Thanks mate. Link to comment Share on other sites More sharing options...
joffa1 Member 143 Member For: 6y 9m 13d Posted 12/11/18 08:35 PM Author Share Posted 12/11/18 08:35 PM I actually looked at going down to 17 or 18 rims and running a higher profile tyre. Had a nice set with good tyres lined up but bloke sold them before I got there. Still keeping an eye out. Ok so 255 width on rear should be ok. What about a slightly higher profile. I.e. 40 on rear and keep the 35 up front? I would imagine this would be ok? Link to comment Share on other sites More sharing options...
joffa1 Member 143 Member For: 6y 9m 13d Posted 12/11/18 11:10 PM Author Share Posted 12/11/18 11:10 PM Have someone selling a set of clean 17s now but with good tyres on and I’m assuming a 45 profile on a 17 inch rim would give a smoother ride? I.e. road noise and bumps not quite as harsh? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 12/11/18 11:17 PM Share Posted 12/11/18 11:17 PM it's all about sidewall and associated flex. it's hard to get good sidewall on 19's/20's but is definitely do-able on 18's and smaller. Link to comment Share on other sites More sharing options...
joffa1 Member 143 Member For: 6y 9m 13d Posted 12/11/18 11:22 PM Author Share Posted 12/11/18 11:22 PM Ok I think I’ll bite the bullet and buy the 17s with the 45 profile tile on them. At least I’ll have a spare set of rims even if I’m not happy with the ride on them. Cheers. Link to comment Share on other sites More sharing options...
