4321 Bronze Donating Members 257 Member For: 10y 28d Posted 06/11/18 09:58 AM Share Posted 06/11/18 09:58 AM (edited) Sounds like a lack of power. Check fuse's under the bonnet & in the cabin. Pull the shroud of the coloum & poke around the back of the ignition switch to see if you have power going in & out. Check that there is 12v at injectors with ignition on. The body control module that k31th was trying to get you to check is between the two arrows on a ba bf in his picture but on the fg it sits vertical behind the RH arrow With limited knowledge there's only so much you can do, I know it's more money but get a professional to look at it before it drives you mad! Edited 06/11/18 09:59 AM by 4321 Link to comment Share on other sites More sharing options...
