Hirdy Member 31 Member For: 5y 10m 29d Posted 30/10/18 06:43 PM Share Posted 30/10/18 06:43 PM Hey guys, just after some advice on future upgrades. So I have 08 bf series 2 xr6 turbo with 4” dump, x force exhaust and cat delete, pod air filter,Turbosmart external wastegate actuator. Car is running 15 psi on boost gauge and was apparently tuned. Has standard fuel pump and injectors and standard intercooler. If I put my foot flat to the floor it will loose power and backfire which is I’m guessing the engine leaning out??? I am about to purchase the following please advise it these will suit before a tune??deka 80lb 850cc injectors, walbro 460lph fuel pump kit and a 4 bar factory fuel regulator upgrade. Thoughts please Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,281 Member For: 16y 7d Gender: Male Location: Melbourne Posted 30/10/18 08:44 PM Share Posted 30/10/18 08:44 PM If it's making 15psi on stock injectors and fuel pump, it's surely leaning out. This can happen with overboost scenario's without actually being tuned after upgrading the exhaust like that. I wouldn't be putting my foot flat to the floor until you're sure it's actually properly tuned to suit the mods. Those mods are fine except two caveats. 1. The injectors may be difficult to tune for your tuner, so find out whether he is OK with using them. 2. The stock charge-air-cooling system won't handle the modifications. You'll make power once or twice, but then it'll heat-soak and you'll be massively down on power compared to the previous one or two pulls. Link to comment Share on other sites More sharing options...
Hirdy Member 31 Member For: 5y 10m 29d Posted 30/10/18 08:50 PM Author Share Posted 30/10/18 08:50 PM Yeah I have rarely put my foot flat because of this. I am picking up a second hand high flow cat today and also a 600x300x80 intercooler.I just had a tinker and looks like hose going to actuator May have been a little loose on the actuator so I cut the end of a refitted it tightly so may have been that also not reading correct boost. Is a fuel pump and regulator required for these mods or can I just fit injectors and have car retuned??? I believe my tuner uses HP tuners program Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,281 Member For: 16y 7d Gender: Male Location: Melbourne Posted 30/10/18 08:58 PM Share Posted 30/10/18 08:58 PM A fuel pump, certainly, is required. A regulator, not so much. You definitely need injectors haha. HP tuners will do the job. Link to comment Share on other sites More sharing options...
Hirdy Member 31 Member For: 5y 10m 29d Posted 30/10/18 09:24 PM Author Share Posted 30/10/18 09:24 PM Ok so I will get the pump and injectors ordered a install than retune. What sort of power you think I should be aiming for approx? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,281 Member For: 16y 7d Gender: Male Location: Melbourne Posted 30/10/18 09:44 PM Share Posted 30/10/18 09:44 PM get your tuner to install the injectors as the car will hardly run after you install them. ask your tuner what his conservative aim would be for the current setup of your car and the associated mods you go with. Link to comment Share on other sites More sharing options...
Hirdy Member 31 Member For: 5y 10m 29d Posted 30/10/18 09:59 PM Author Share Posted 30/10/18 09:59 PM Ok mate thanks for your help Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,281 Member For: 16y 7d Gender: Male Location: Melbourne Posted 30/10/18 10:47 PM Share Posted 30/10/18 10:47 PM no worries 1 Link to comment Share on other sites More sharing options...
pottypirate New Member 18 Member For: 9y 1m 15d Posted 01/03/20 02:08 AM Share Posted 01/03/20 02:08 AM Hirdy your a bum get back to work, no doubt all these questions are on work time and computers. Ask the colonel he'll be able to sort ypu out Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 17d Gender: Male Location: Adelaide Posted 01/03/20 02:53 AM Share Posted 01/03/20 02:53 AM Piks of Hirdy’s bum ? Link to comment Share on other sites More sharing options...
