dutchy351 Member 41 Member For: 10y 3m 13d Posted 27/10/18 03:00 AM Share Posted 27/10/18 03:00 AM Hey guys I'm curious about catch can setups and trying to work out the best option to go for. From what I see the most common option that people use is removing the pcv valve and running a hose directly to the catch can, and then running a hose from the front rocker cover breather to the catch can and venting catch can to atmosphere via a small air filter. Now while this seems to be the most common setup I've seen I have recently been told that this setup can cause extra issues in the way of pushing seals (normally rear main) out fairly often and causing oil leaks, but that's the first time I had ever heard it. Can anyone comment on this? Any suggestions on the best possible setup to go for? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 21d Gender: Male Location: Perth Posted 27/10/18 11:26 AM Share Posted 27/10/18 11:26 AM I have many posts on it. Use search. Link to comment Share on other sites More sharing options...
dutchy351 Member 41 Member For: 10y 3m 13d Posted 27/10/18 10:14 PM Author Share Posted 27/10/18 10:14 PM I tried search but found nothing in this specific issue, hense the full thread. Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 11m 16d Gender: Male Location: Western Sydney Posted 27/10/18 11:34 PM Share Posted 27/10/18 11:34 PM The idea of a vented can is to relieve any pressure build up, of the lines are decently sized you'll have no chance of blowing out seals.It's when stock sized lines are used with high powered motors that you'll have issues.Like arronm said theres alot of info around here on them. Link to comment Share on other sites More sharing options...
