LucasFGMK2F6 New Member 10 Member For: 5y 5m 12d Posted 16/10/18 10:56 AM Share Posted 16/10/18 10:56 AM Hey guys, getting a catback exhaust, 1000cc injectors, 800hp cooler and an air intake on my fg mk2 f6, how much power would I make and is there anything else that would need changing? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,240 Member For: 15y 11m 19d Gender: Male Location: Melbourne Posted 16/10/18 11:27 AM Share Posted 16/10/18 11:27 AM you'll be limited by the stock cat to about 300-320rwkw, I'd imagine, with those mods. Link to comment Share on other sites More sharing options...
LucasFGMK2F6 New Member 10 Member For: 5y 5m 12d Posted 17/10/18 05:47 AM Author Share Posted 17/10/18 05:47 AM Hey guys! Got $5k to spend on my FG MK2 F6, was thinking a tune and catback exhaust for $2300, new intercooler, injectors and a modified air intake, how much power would I see? Is there anything else needed? Is there any better options? The catback is a must as the exhaust is cracked. Ok, how much extra do you think a cat would cost? I've read people running 400kw with just a catback exhaust. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,240 Member For: 15y 11m 19d Gender: Male Location: Melbourne Posted 17/10/18 05:53 AM Share Posted 17/10/18 05:53 AM I've never heard of a car running anywhere near that with only a catback. to buy a cat is a coupla hundred or so... ... or extremely cheap if you're willing to just remove the contents (this is very illegal). Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,980 Member For: 11y 1m 3d Gender: Male Location: Frankston, 3199 Posted 17/10/18 05:56 AM Share Posted 17/10/18 05:56 AM The MK2 has a "bung" in the cat that can be knocked out, removing most of the restriction Link to comment Share on other sites More sharing options...
LucasFGMK2F6 New Member 10 Member For: 5y 5m 12d Posted 17/10/18 05:57 AM Author Share Posted 17/10/18 05:57 AM ok so everything should be good there? How much power would I see? I'm not really wanting a full exhaust as I don't want really big power, people have ran 400rwkw on an xforce catback exhaust which is what I am planning on buying. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,240 Member For: 15y 11m 19d Gender: Male Location: Melbourne Posted 17/10/18 06:02 AM Share Posted 17/10/18 06:02 AM 400rwkw is about the area you start fatiguing driveline components... so if you think that's only a small amount, you're in for a surprise. 400rwkw is a mid 10sec car, if setup correctly. since the cat is the restriction, if you "un-restrict" the cat (by replacing with a better one or other methods), then you can probably make 400rwkw on a reasonable cat-back replacement. The stock turbo is going to max out around the high 300's unless you tune it on E85. If you tune it on E85 you may as well upgrade the turbo and fuel system, then you're looking at major driveline risk at 450+ haha, it never ends. Anything past about 350rwkw starts getting expensive, especially if you take it to the drag-strip with slick tyres. Link to comment Share on other sites More sharing options...
LucasFGMK2F6 New Member 10 Member For: 5y 5m 12d Posted 17/10/18 06:05 AM Author Share Posted 17/10/18 06:05 AM Oh ok, I'd hit 400kw with those sort of mods? I'd definetly talk to my tuner if I can un-restrict it, most people are running 400rwkw or under on a stock FG F6 turbo as my tuner has also told me, above 400 it will definetly need to be replaced I was told, it'll just be a street car, run a time and see what I get. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,240 Member For: 15y 11m 19d Gender: Male Location: Melbourne Posted 17/10/18 06:08 AM Share Posted 17/10/18 06:08 AM Without a turbo replacement, you'll be pushing the stock turbo really hard to hit 400rwkw. Your tuner is right. Ask your tuner what you think you'll get with the mods you listed and make that a conservative aim, assuming the car is in good enough condition to produce the power Link to comment Share on other sites More sharing options...
LucasFGMK2F6 New Member 10 Member For: 5y 5m 12d Posted 17/10/18 06:15 AM Author Share Posted 17/10/18 06:15 AM ok thanks mate Link to comment Share on other sites More sharing options...
