jas98 Member 1,029 Member For: 11y 8m 27d Gender: Male Location: Maryborough Qld Posted 14/09/18 12:20 AM Share Posted 14/09/18 12:20 AM Hi. Have a ba xr6t Changed oil about 4500 ks ago and filter For last couple weeks have noticed first start in morning theres a engine rattle seems to last aboit 30 to 40 seconds then its like turning off a switch and is quiet again. Toe it sounded like passenger side of engine. (Could be starter motor not retracting?) Oil im useing is penrite 15 40. And a ryco oil filter Does this sound like oil is not pumping quick enough to top end? Ill give it a oil and filter change as I have had problems with tyco filters before. But if its a bearing or oil pump it be doing it all time?? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,116 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 14/09/18 02:16 AM Share Posted 14/09/18 02:16 AM Got a vid mate? Does it only do it when it's cold? What if you start it and let the noise go away, will it do it again if you turn it off and restart the car? Link to comment Share on other sites More sharing options...
EvilDaifu Cruise Whore Moderating Team 5,128 Member For: 18y 8m 14d Gender: Male Location: Melbourne Posted 06/10/18 08:31 PM Share Posted 06/10/18 08:31 PM I had an engine rattle in my F6 recently. Pitlane thought it might be timing guide as they are plastic and can break so took timing cover off and nope was all okay. My rattle was front passenger side of engine as well. Was worse in mornings starting cold. Turned out to be idle pulley and rubber belt tensioner causing the rattle (had to change out idle pulley on my BA T as well when I had one). Replaced them brand new as well as new rubber belt and was all good! Hope that helps Link to comment Share on other sites More sharing options...
