pdidily6401 Member 57 Member For: 5y 8m 19d Posted 21/09/18 04:14 AM Author Share Posted 21/09/18 04:14 AM yup, how critical is it to replace the "k" brace the sits between turbo and engine mount, seen a couple of comments where they have not put it back on. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 21/09/18 04:18 AM Share Posted 21/09/18 04:18 AM I just leave it off, personally. Never had a problem as long as you tighten the manifold bolts/nuts often enough. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,044 Member For: 9y 1m 28d Gender: Male Location: South Australia Posted 21/09/18 04:34 AM Share Posted 21/09/18 04:34 AM Technically you could drive around with 3 wheel nuts per wheel if you wanted to. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 1d Gender: Male Location: Perth Posted 21/09/18 04:49 AM Share Posted 21/09/18 04:49 AM 34 minutes ago, pdidily6401 said: yup, how critical is it to replace the "k" brace the sits between turbo and engine mount, seen a couple of comments where they have not put it back on. Its there for a reason, but it back on.... Link to comment Share on other sites More sharing options...
pdidily6401 Member 57 Member For: 5y 8m 19d Posted 21/10/18 09:32 AM Author Share Posted 21/10/18 09:32 AM Ok new actuator fitted turbo smart 7.5 psi all good boost wise now not exceeding 8psi on gauge decided to give car a good run am now at bottom of South Island and what days know engine just cuts out while idling along it turns over good but won’t fire towed to garage no fault codes registered have ordered new fuel pump as mechanic thinks this is issue any advice What days was whaddayaknow Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,044 Member For: 9y 1m 28d Gender: Male Location: South Australia Posted 21/10/18 09:42 AM Share Posted 21/10/18 09:42 AM Swap the fuel pump and let us know. I'm sure the mechanic would have listened to it priming or rather the lack of it priming so you should be sweet after this. It should be pretty cheap too as the pump doesn't cost much and it doesn't take long to install. Link to comment Share on other sites More sharing options...
pdidily6401 Member 57 Member For: 5y 8m 19d Posted 21/10/18 10:03 AM Author Share Posted 21/10/18 10:03 AM Yup he has given me the run of the garage so going to pull pump tomorrow can hear it prime but no pressure in the line disconnected at pump and turned key could hear pump prime but no fuel pressure Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,044 Member For: 9y 1m 28d Gender: Male Location: South Australia Posted 21/10/18 10:12 AM Share Posted 21/10/18 10:12 AM Mebbe it's got a busted line from the pump in the tank. You'll soon see anyway. Link to comment Share on other sites More sharing options...
pdidily6401 Member 57 Member For: 5y 8m 19d Posted 23/10/18 09:02 PM Author Share Posted 23/10/18 09:02 PM And sure enough pulled fuel pump and hose from pump to top of housing was disconnected refitted and fastened with hose clamp and have driven some 600k’s back with no issues 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 23/10/18 11:54 PM Share Posted 23/10/18 11:54 PM Good job on getting it sorted... It's a reasonably common thing to occur when fuel pumps are installed. Link to comment Share on other sites More sharing options...
