BarraRx7 Member 46 Member For: 5y 3m 13d Posted 17/12/18 10:43 PM Share Posted 17/12/18 10:43 PM Hey I just joined the page and I'm doing a barra swap in to my fc rx7. I live down in Fort Myers, but my car is at my buddy's house in North Port, so we aren't to far apart. I wouldn't mind talking to you about some different things you've run into with the engine . Nice build ! Link to comment Share on other sites More sharing options...
SelectivePC Member 79 Member For: 5y 6m 26d Posted 19/12/18 02:58 AM Author Share Posted 19/12/18 02:58 AM Thanks man, glad to see more coming to the U.S. and yeah anytime. Let me know ill PM you with my info. Properly prepped, time for some rocker boxes. 1 Link to comment Share on other sites More sharing options...
SelectivePC Member 79 Member For: 5y 6m 26d Posted 02/01/19 11:49 PM Author Share Posted 02/01/19 11:49 PM (edited) Finally started. Trying to retain the use of the Targa top. Soon.... Edited 02/01/19 11:50 PM by SelectivePC 3 Link to comment Share on other sites More sharing options...
SelectivePC Member 79 Member For: 5y 6m 26d Posted 17/02/19 12:22 AM Author Share Posted 17/02/19 12:22 AM Little update, still here....just stuck on the drawing board..... lol so as expected its a bit taller the oem stuff....but ideas are brewing and hopefully get it tucked down in the bay. 2 Link to comment Share on other sites More sharing options...
HI PSI Member 1,563 Member For: 17y 10m 4d Gender: Male Location: Central Queensland Posted 17/02/19 01:38 AM Share Posted 17/02/19 01:38 AM A nice reverse cowl scoop would solve your issues. 😄 Link to comment Share on other sites More sharing options...
SelectivePC Member 79 Member For: 5y 6m 26d Posted 17/02/19 04:26 PM Author Share Posted 17/02/19 04:26 PM I would really like to keep a stock hood on it if possible. We have some ideas in mind to lower mounting points on the sub frame and space it down as well. 1 Link to comment Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 7y 7m 14d Posted 17/02/19 11:48 PM Share Posted 17/02/19 11:48 PM It’s going to be a tight fit even if you drop it down. Looks almost 2” to tall and the way the front of the bonnet droops on those could be an issue... how much room room do you have in the subframes to lower it? Link to comment Share on other sites More sharing options...
SelectivePC Member 79 Member For: 5y 6m 26d Posted 19/02/19 08:50 PM Author Share Posted 19/02/19 08:50 PM So the JZA70 chassis has after market sub frame spacers available. So it will drop an inch there, as far as the rest, after looking at he hood for clearance, maybe an inch will be gained from removing the under mat from the hood. as well as some bracing in the framing of the hood. Worst case the vehicle will be a track whore that will be drifted as much as possible. So if a hole needs to be cut in the hood so be it!! Link to comment Share on other sites More sharing options...
SelectivePC Member 79 Member For: 5y 6m 26d Posted 20/02/19 06:29 PM Author Share Posted 20/02/19 06:29 PM So in some other good news, test fit the new Flywheel and starter setup to make sure everything plays nicely. Now we can finish making the adapter plate and clutch set-up. Side note, yes we know the starter did not disengage, the Bendex itself will be spun off the ring gear once the engine is started. 1 Link to comment Share on other sites More sharing options...
SelectivePC Member 79 Member For: 5y 6m 26d Posted 07/06/19 01:52 PM Author Share Posted 07/06/19 01:52 PM (edited) Update, build isn't dead yet. So the trans adapter to the Nissan CD009 has been completed, trying to test fit this weekend and make sure everything works nicely together.. more updates to come soon! Edited 07/06/19 01:54 PM by SelectivePC 3 Link to comment Share on other sites More sharing options...
