Barra build in the U.S.
  • Member For: 5y 7m 18d
So today was a great day. Had some customers fall through, so had a bit of time today.
Swapping the front sump girdle for a rear sump version.
Re-torquing the main bolts.
New rear main seal while im in there.
And new rear mounted pick-up.
Oil pan installed, and cross bolts with thread sealant.
And finally!!!! The two together.
ARP calls for 125ft. lbs, for the random bolts I had to order. Done and done. *Note to self, head bolts are not easily accessed with cams installed already, so small learning curve.
Cams reinstalled. (Again)
And started getting some timing ready to do, but enough for today. :)
  • Like 6
  • Bronze Donating Members
  • Member For: 10y 23d
Not really to late now, but if you look at the head stud washers they're not wide enough, maybe wonder off to a bolt place & see if you can find better fitting ones (Atomic sell them & I think they give the size  on their website)
  • Puff
  • Member For: 9y 2m 21d
They're 28mm. Here is an ebay listing for them. If they wont post to Florida, I'll buy some and send them over if ya like. I don't see why you couldn't just use any other 28mm washer, providing it didn't lose tension on the head or deteriorate over time.
https://www.ebay.com.au/itm/HP-XR6-Turbo-12mm-Head-Stud-Washers-28mm-OD-BA-FG-including-Territory-FPV/113254985941?hash=item1a5e85f0d5:g:ZzUAAOSwRbtaAEj0:rk:1:pf:0
Ok ill have to take some measurements to tomorrow, and see what I can do about this.
OK so, my only issue with this is the ARP studs are not going to be long enough either now. After measuring out all of their requested numbers, this is the stud that would fit, and currently the nut runs down level with the top of the stud.
  • Puff
You can put steel ball bearings in the block so the studs are raised up a bit.
  • Haha 1
