jacob_xr6turbo Donating Members 433 Member For: 16y 7m 11d Location: Richmond, Melbourne Posted 04/09/18 11:06 AM Share Posted 04/09/18 11:06 AM Hey guys, Just wondering if anyone would know why my clutch would be making a whirring noise when launching in first gear, or even in reverse, followed by a bad clutch smell.. ? Car drive perfectly fine otherwise, and clutch holds fine under boost. There just seems to be an issue when im launching up hill or reversing up an incline, etc. I'm not riding the clutch or anything, literally just feels like the clutch can't engage properly as soon as there is a hill or incline that I'm driving up.. Thanks, Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,299 Member For: 16y 13d Gender: Male Location: Melbourne Posted 04/09/18 11:07 AM Share Posted 04/09/18 11:07 AM sounds like it's slipping because the CSC is dragging on the diaphragm of the clutch... Link to comment Share on other sites More sharing options...
jacob_xr6turbo Donating Members 433 Member For: 16y 7m 11d Location: Richmond, Melbourne Posted 04/09/18 11:09 AM Author Share Posted 04/09/18 11:09 AM Thanks Keith, makes sense as I am also getting some clutch drag when downshifting.. Know the best place to order a new CSC? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,299 Member For: 16y 13d Gender: Male Location: Melbourne Posted 04/09/18 11:12 AM Share Posted 04/09/18 11:12 AM mal wood do a metal replacement The crappy plastic one is no good. Also, while you're at it, get a remote bleeder line as it'll make maintaining your clutch fluid much easier 1 Link to comment Share on other sites More sharing options...
jacob_xr6turbo Donating Members 433 Member For: 16y 7m 11d Location: Richmond, Melbourne Posted 04/09/18 11:17 AM Author Share Posted 04/09/18 11:17 AM Thanks Keith, it has a remoter bleeder and apparently already has a mal wood twin plate upgraded clutch... I can confirm the remote bleeder as I used it to bleed my clutch fluid a few months back. If it has the remote bleeder im sure it is the metal CSC as part of the mal wood kit. I will order a CSC and take it to the shop to inspect. Is there anything else I should order/replace if im changing the CSC? Spigot, thrust bearing or anything? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,299 Member For: 16y 13d Gender: Male Location: Melbourne Posted 04/09/18 11:20 AM Share Posted 04/09/18 11:20 AM hmm, yeah, it probably does have a metal one already... haven't heard of one of those causing problems, so I'd guess you'll just need to pull the box out to inspect the situation of the clutch/csc etc. You can take a quick peek in the bleeder hole to see if you can see anything aligned or moving when it shouldn't. but yeah, while the box is out, always replace the input shaft thrust bearing (the part where it pushes into the crank). The rest is just a matter of doing the work. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 27d Gender: Male Location: Perth Posted 04/09/18 04:34 PM Share Posted 04/09/18 04:34 PM I had an alloy csc fail. It can happen. Use an inspection USB camera to check the clutch internals Link to comment Share on other sites More sharing options...
jacob_xr6turbo Donating Members 433 Member For: 16y 7m 11d Location: Richmond, Melbourne Posted 25/09/18 12:26 PM Author Share Posted 25/09/18 12:26 PM (edited) guys this is just a quick shot of under my car.. is the bellhousing meant to not line up properly and have holes in the side there? https://1drv.ms/u/s!AozJGemTOSiRhJ8ao-x8S50AIE6jkA Edited 25/09/18 12:27 PM by Christiaan Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 27d Gender: Male Location: Perth Posted 25/09/18 01:28 PM Share Posted 25/09/18 01:28 PM No. There is as plate missing between the engine and box. Link to comment Share on other sites More sharing options...
