G6EEEETTTT Member 27 Member For: 5y 7m 28d Posted 22/08/18 12:47 AM Share Posted 22/08/18 12:47 AM What rpm should a G6ET idle at? Mine sits just a tad over 500 rpm and that seems a bit low to me. Stock engine. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,290 Member For: 16y 8d Gender: Male Location: Melbourne Posted 22/08/18 12:53 AM Share Posted 22/08/18 12:53 AM all stock 6cyl falcons idle around 6-800rpm depending on temperature of components (obviously a bit higher than this when it's stone cold). You'll notice issues like it chugging and trying to stall, if it's idling too low. If it's running smoothly, there's no cause for concern Link to comment Share on other sites More sharing options...
BigKriss Member 42 Member For: 12y 4m 20d Gender: Male Location: Sydney, Australia Posted 22/08/18 01:28 AM Share Posted 22/08/18 01:28 AM Yeah mine is around 6-800 cold It goes down to around 500 when warm 1 Link to comment Share on other sites More sharing options...
G6EEEETTTT Member 27 Member For: 5y 7m 28d Posted 22/08/18 02:12 AM Author Share Posted 22/08/18 02:12 AM Sounds like mine is normal then. Cheers. 5 hours ago, k31th said: all stock 6cyl falcons idle around 6-800rpm depending on temperature of components (obviously a bit higher than this when it's stone cold). You'll notice issues like it chugging and trying to stall, if it's idling too low. If it's running smoothly, there's no cause for concern Cheers. It does idle smooth but just seems like it is a bit lower than it should be. And it moves forward quite slowly in D from a dead stop with no throttle. Just seems a bit different from the other FG's I've driven. Link to comment Share on other sites More sharing options...
