SIMBAD Donating Members 150 Member For: 12y 3m 14d Gender: Male Location: Tumut Posted 09/10/18 05:47 PM Author Share Posted 09/10/18 05:47 PM Thanks puff Link to comment Share on other sites More sharing options...
SIMBAD Donating Members 150 Member For: 12y 3m 14d Gender: Male Location: Tumut Posted 09/10/18 08:38 PM Author Share Posted 09/10/18 08:38 PM I have pieced together a exhaust already. Ive a used 4” nizpro dump,new 4” ballistic cat with 5” body 100 cell and a used mild steel 3.5” xforce. I’m somwhere around $900 without all gaskets and need flanges for the cat. I might try put some time in this week to fit the new diff bushes and while the car is jacked up on stands I could install the cat back exhaust for the moment. I would do the full exhaust but have read numerous times it’s not wise unless I’m ready for a tune which is some time away yet. Or would I get away with fitting the dump pipe but still using the standard cat as some form of restriction in the exhaust? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 27d Gender: Male Location: South Australia Posted 09/10/18 09:16 PM Share Posted 09/10/18 09:16 PM The standard wastegate setup isn't great so it'll overboost if you floor it. You can install the lot of it but you'd have to control the boost to some degree with your right foot. If you drive it hard every day then it's probably better to leave it stock for now. 1 Link to comment Share on other sites More sharing options...
SIMBAD Donating Members 150 Member For: 12y 3m 14d Gender: Male Location: Tumut Posted 11/10/18 12:09 PM Author Share Posted 11/10/18 12:09 PM Spewing I missed the rear brembos... but anyways, I’ve got the more important front ones and they will be enough I’m sure. I cleaned them up as much as I could care to today. I’ve decided I’m going to paint them anyway so will be sand blasting the original paint off. I left the colour choice up to my wife and she has come back with the candy green. #2 from that colour card chart I posted up earlier. So ordered that paint kit this arvo and will also be making up brembo stencils so I can paint the brembo logo on in black. The original paint is missing a lot of clear coat. Also checked and found the pistons and seals all appear to be fine but I think I’ll order new dust boots and seals anyway. They are 40mm and 44mm on both callipers. Dust boots: >20.4872.46 (40mm) >20.4872.48 (44mm) seals: >05.5955.58 (40mm) >05.5955.60 (44mm) mandatory pics of current condition: rotors and pads: I can’t comment on what the RDA & ebc red stuff pads combination is like but I feel I might move these on anyway and buy new dba t3 rotors and matching dba xp pads. For the front: dba t3 (dba 42102s “355mm x 32mm”) and dba pads to suit (db1935xp) For the rears: dba t3 (42108s “328mm x 26mm”) Also I gave a thought to use the “SP” pads over the “XP” pads but not 100% sure just yet. The “XP” pads look very good all round according to that chart above.. Dba XP pads (db1675xp) Dba SP pads (db1675sp) Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 29d Posted 11/10/18 06:43 PM Share Posted 11/10/18 06:43 PM I tried the ebc reds & I thought they were quite good, low dust, quite & worked good from cold. It's your choice but I'd give them a go see what you think 1 Link to comment Share on other sites More sharing options...
SIMBAD Donating Members 150 Member For: 12y 3m 14d Gender: Male Location: Tumut Posted 17/10/18 11:25 PM Author Share Posted 17/10/18 11:25 PM (edited) On 09/10/2018 at 9:04 PM, SIMBAD said: Ok so going back to these injectors. The bloke has dropped his price a little more. At this stage he’s $500 plus $10 postage. For some reason I thought they came off a FG but must of been a different advert I’d seen else where. They are in fact suited to b series with the longer style purple injector adapters. they actually come of a bf F6. he is still adamant that they are roughly 10k old as well. only changed because of bigger turbo and needing over 2200cc injectors to keep fuel up to it. So I guess im still unsure if it’s a good deal or not? Also another thing of interest to me is changing to a T04s style surge slotted .7ar 4” in 2.5” out compressor cover. I found a interesting thread on using said cover,backing plate and retainer bracket/clamps on standard turbo and his claimed results are interesting. I haven’t found any more really good info on this yet but here it is: Edited 17/10/18 11:27 PM by SIMBAD Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 27d Gender: Male Location: South Australia Posted 17/10/18 11:36 PM Share Posted 17/10/18 11:36 PM That's a fair price. There's a set of new ones on fleabay for a tad over $800. 1 Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 29d Posted 18/10/18 07:50 AM Share Posted 18/10/18 07:50 AM If you get them cleaned & flow tested there's more money, getting close to new price with NO warranty Usually new one's come with wiring plug adaptors which you'll have to source as well as the injector data for your tuner 1 Link to comment Share on other sites More sharing options...
adams355 Member 529 Member For: 6y 11m 24d Gender: Male Location: Brisbane Posted 18/10/18 09:19 AM Share Posted 18/10/18 09:19 AM (edited) Raceworks 1000cc are decent. Mine idle perfectly, never had an injector issue and they are decent price. They were installed by a very well known tuner who uses them on most of their cars... I think these are the right ones https://www.ebay.com.au/itm/1000cc-Raceworks-3-4-Length-INJ-154/273480586693?hash=item3facb695c5:g:gzkAAOSwNDZbMu7f:rk:2:pf:0 There are others with 2 yr warranty as well. Edited 18/10/18 09:23 AM by adams355 1 Link to comment Share on other sites More sharing options...
SIMBAD Donating Members 150 Member For: 12y 3m 14d Gender: Male Location: Tumut Posted 18/10/18 10:11 AM Author Share Posted 18/10/18 10:11 AM 2 hours ago, 4321 said: If you get them cleaned & flow tested there's more money, getting close to new price with NO warranty Usually new one's come with wiring plug adaptors which you'll have to source as well as the injector data for your tuner Yeah that’s also a good point to concider. But even when new they would need to be flow tested anyways just to make sure Link to comment Share on other sites More sharing options...
