turtle61 New Member 4 Member For: 7y 20d Posted 08/08/18 09:07 AM Share Posted 08/08/18 09:07 AM this car wont start, feels like no fuel, fuse & relay are good but no sound from rear when ignition is turned on, where is the fuel pump? cheers Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,403 Member For: 14y 3m 24d Gender: Male Location: Melbourne Posted 08/08/18 10:53 AM Share Posted 08/08/18 10:53 AM its in the fuel tank magic 1 Link to comment Share on other sites More sharing options...
espoig Donating Members 249 Member For: 9y 7m 13d Gender: Male Location: Mundaring Posted 08/08/18 11:25 AM Share Posted 08/08/18 11:25 AM Have too drop the tank 1 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 22d Gender: Male Location: Perth Posted 08/08/18 02:39 PM Share Posted 08/08/18 02:39 PM Yep, drop tank. https://drive.google.com/file/d/1fO_xT8drgsOMEFjdKdc3U1-HgUx35hOD/view?usp=sharing Link to comment Share on other sites More sharing options...
Craigoss Member 26 Member For: 6y 1m 16d Posted 21/12/18 11:27 AM Share Posted 21/12/18 11:27 AM I have a walbro 460. Can I install it without a tune or will there be too much pressure for a standard engine? Link to comment Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 8y 6m 10d Gender: Male Location: Mildura Posted 21/12/18 11:49 AM Share Posted 21/12/18 11:49 AM Stock fuel pressure regulator probably won't be able to hold back the pressure. You'll need an aftermarket reg and possibly fuel rail. GFB do a direct replacement reg, turbosmart do an adaptor fitting to run an external reg. Link to comment Share on other sites More sharing options...
BeerTurbo Donating Members 234 Member For: 5y 11m 9d Posted 30/03/19 03:47 AM Share Posted 30/03/19 03:47 AM Can confirm a Walbro 460 delivers to much fuel for the stock reg to handle, mine was sitting at around 75 psi fuel pressure at idle when it should have been a tad under 60. have heard some people drill out the return on the stock regulator, this requires precision as if you hit the wrong thing u will need a replacement reg. the return patch through the stock regulator is something like 2MM its a baby for high volume pumps. plenty of company's make fittings/bolt in regulators if you want to just take that path. Link to comment Share on other sites More sharing options...
