Renton Member 151 Member For: 6y 13d Gender: Male Location: Perth Posted 15/08/18 10:29 PM Share Posted 15/08/18 10:29 PM Thanks for the reply. Sorry bad choice of words. Was more referring to the standard motor/internals. As you said maybe building a motor later on. So no real disadvantages running a bigger injector for now? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 15/08/18 10:56 PM Share Posted 15/08/18 10:56 PM It'll be fine on e85 but would likely have low pw issues on 98. Not ideal but not the end of the world either. To clarify my 70% idc estimate, head over to the injector dynamics fuel flow calculator and see what you get when you plug in a 3 bar base fuel pressure, 0.78 lambda and 25 psi boost pressure. Generally you wouldn't choose an injector that big but there are reasons that you might do so, such as headroom or just having them lying around. 1 Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 8y 11m 28d Gender: Male Location: Canberra ACT Posted 15/08/18 11:47 PM Share Posted 15/08/18 11:47 PM It is a good general question. I've often wondered why people put monster injectors in 98 cars with moderate power, when surely the cost and idle/cruise characteristics would be better with something smaller. Probably a mix of bragging rights, shops wanting to upsell to a more expensive product and shops knowing that customers will be back for more power later. In this case though, yeah it's E85 and the package is clearly aiming at considerable power. Edit: haha what the heck was with the Family Guy bit at the start?? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 9d Gender: Male Location: Melbourne Posted 15/08/18 11:51 PM Author Share Posted 15/08/18 11:51 PM yeah; plenty of shops spruik 1000cc injectors at a minimum, seemingly because they had easy to tune capabilities plus the extra mark up of the upsell. Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 8y 11m 28d Gender: Male Location: Canberra ACT Posted 16/08/18 12:00 AM Share Posted 16/08/18 12:00 AM And, which is fair enough, for copy and paste ability. If I was tuning every day I'd rather be able to quickly do an outstanding job on a couple of different injectors rather than spending more time doing an ok job on lots of various injectors. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 9d Gender: Male Location: Melbourne Posted 16/08/18 12:03 AM Author Share Posted 16/08/18 12:03 AM indeed... I'm not 100% familiar with the scaling/flow/spray requirements for different injectors, but it can't be that hard, can it Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 8y 11m 28d Gender: Male Location: Canberra ACT Posted 16/08/18 12:55 AM Share Posted 16/08/18 12:55 AM That's reminded me - I did some scaling for Bosch 968s as I was about to buy them for the BA. The data available was for a range of fuel pressures, but not 4 bar. I wanted to go through the process of doing it myself rather than just copying from someone else, so did some calcs and then was going to dial in on the road.I'll post them up later, maybe in the DIY tuning thread, to see if the approach I used was correct. I basically graphed the data I had and used a line of best fit to work out 4 bar values.Won't use the values now as I'll use a different injector in the FG (maybe Bosch 57lb or something). Would still be useful to know if I'm understanding the concepts correctly though. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 9d Gender: Male Location: Melbourne Posted 16/08/18 12:56 AM Author Share Posted 16/08/18 12:56 AM definitely chuck that information into the DIY tuning thread Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 23d Gender: Male Location: Perth Posted 16/08/18 01:28 AM Share Posted 16/08/18 01:28 AM (edited) 1 hour ago, k31th said: yeah; plenty of shops spruik 1000cc injectors at a minimum, seemingly because they had easy to tune capabilities plus the extra mark up of the upsell. Big jump in price from 1000cc to 1300cc to 1700cc. 1000cc will see you over 500 on e85. I think about 550 it should be 1300s and then larger Iam not sure. BUT just choose the smallest injectors for your ultimate power goal. But these days large injectors can idle nice , not like the old days. Tuners use the same 1000cc as they have all the tuning tables calculated so easier to tune. Having raced cars and bikes, its not just the flexing of the car /bike but vibrations from high RPM that fracture components. Rubber mounting items is an old trick, which seems to have been forgotten these days. BUT not buy the older guys that really know... FULLY rubber mounted. Edited 16/08/18 01:29 AM by arronm Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 16/08/18 02:21 AM Share Posted 16/08/18 02:21 AM My bosch 1000's were at 50% at 17.25psi/6100rpm on 98 with 0.8ish lambda. No idle issues running stoich on 98 and still had something left at 21psi on e85 (I didn't check how much though). That will give some idea about the necessity of having "1000cc" injectors. Haha I recommend that size cos they work on 98 and there's headroom for e85 but they are overkill for most cars. Link to comment Share on other sites More sharing options...
