Gun40t Member 98 Member For: 6y 8m 20d Posted 30/07/18 10:19 AM Share Posted 30/07/18 10:19 AM hey guys so recently I removed my cam tunnels to get the rocker cover bolt holes retapped as the previous owner stripped them, ive put them back and an tightened them down just wondering if I have to fix timing or anything like that as one of the cams have raised up at the rear of the motor nothings bent it just raised as I removed the cam tunnels... everything back together so I need to turn the motor over by hand or can I just prime it and start it cheers Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 30/07/18 10:32 AM Share Posted 30/07/18 10:32 AM as long as the alignment went in the same way that you removed it, it should be fine. Link to comment Share on other sites More sharing options...
Gun40t Member 98 Member For: 6y 8m 20d Posted 30/07/18 10:33 AM Author Share Posted 30/07/18 10:33 AM alignment as in the cam tunnels? I marked the front and rear left and right back tighten them from the middle to the outside in sequence thankyou keith your a champ!!! I always count on u dude Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 30/07/18 10:36 AM Share Posted 30/07/18 10:36 AM while its apart, I'd be checking the timing, just as a "to be sure" sort of thing, but yeah, good stuff Link to comment Share on other sites More sharing options...
Gun40t Member 98 Member For: 6y 8m 20d Posted 30/07/18 10:38 AM Author Share Posted 30/07/18 10:38 AM I think we spoke about this before, and I was to scared to do it haha, but I did it, I dont have a timing gun, if I start the car and take it to a shop they can check it yeah? I just started it it's idleing really rough Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 11m 18d Gender: Male Location: Western Sydney Posted 30/07/18 11:18 AM Share Posted 30/07/18 11:18 AM Free cams lol Link to comment Share on other sites More sharing options...
Gun40t Member 98 Member For: 6y 8m 20d Posted 30/07/18 12:58 PM Author Share Posted 30/07/18 12:58 PM if only it was free power lol if the cam tunnels are fitted wrong way will the car run like sh*t please it's worried me Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 30/07/18 01:25 PM Share Posted 30/07/18 01:25 PM Unless you've really farked it up then no. You said you marked it all so you should be ok. Let's assume you have the cam caps fitted properly or at least torqued down properly. You could have messed up the cam timing. You could have left a coil plug off. You could have left a cam phaser plug off. You could have forgotten to fit both tb plugs. It's there a vacuum hose off? Not giving you grief but you could have done any number of random things that people do when they don't know what they're doing. Double check this. Don't run the car for extended periods until you have verified that everything is correct. Check the various plugs first. If there is no valve on piston noise when it was running then check the cam timing. Key the engine over as it'll take friggin ages by hand. Don't worry about the crank mark for now. Just confirm that the coloured links line up on the dots on the cam gears. Link to comment Share on other sites More sharing options...
Gun40t Member 98 Member For: 6y 8m 20d Posted 30/07/18 01:29 PM Author Share Posted 30/07/18 01:29 PM thanks heaps man, I'm guna check the timing I plugged everything in. I'm 99% sure it sounds like it was running on like 4 cylinders.. I've never had this problem.. all I did was remove the tunnels the rocker cover threads tapped, put them back on I put the rear ones upside down, tried to start it motor kicked over and it sounded like it like a bad misfire, never had a problem with the car I connected throttle body plugs, everything that needed to be done properly.. I'm guessing because the cam tunnel was fitting wrong it's caused this if switched it now, also may have slipped a tooth not to sure Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 30/07/18 01:44 PM Share Posted 30/07/18 01:44 PM At worst you would chew out the head or cap if the journal was offset a bit. You could score the cam too if it ran for long enough. The car would still run fine but would lose a bit of oil pressure eventually and obviously you would have to replace whatever got chewed up. Check your rear caps for peace of mind if you like but I'd be looking elsewhere for a funky miss. I left my small tb plug off once and it idled like sh*t. Just double check the various plugs cos that's easy and then check the cam timing. If there's anything super obvious that you haven't mentioned then check that too cos sometimes it is a simple fix. Link to comment Share on other sites More sharing options...
