karlp2 Member 81 Member For: 10y 8m 8d Gender: Male Location: Auckland, New Zealand Posted 25/07/18 07:21 PM Share Posted 25/07/18 07:21 PM Turbo upgrade, have a G6ET with a stock 3576 turbo with the porting and flapper mod, looking to upgrade to the GTX3582R Gen 2. When ordering I just want to make sure I’m getting everything needed, my questions 1) there’s a couple options around the flapper size and the actuator size - what is recommended? 2) Also reading through I understand I need a couple reducers but can’t see any details to guide me on what exactly I need to order? Current supporting mods: Walbro 400 pump, 1000cc injectors, P/W stage 1 intercooler, and a full xforce (twin 2.5”) exhaust. Cheers for your help Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 25/07/18 11:11 PM Share Posted 25/07/18 11:11 PM 1) 38mm wastegate/flapper, whatever PSI actuator you want your MINIMUM boost to be 2) reducers... I think you mean oil restrictors. The turbo supplier should be able to tell you what you need there for your motor and turbo combination and either supply them or tell you what specifically to buy. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 25/07/18 11:23 PM Share Posted 25/07/18 11:23 PM 4 minutes ago, k31th said: reducers I thought he meant silicone aye? You don't want an oil restrictor with that turbo. The turbo has a 4 inch inlet and a 2.5 inch outlet so you wanna plan your joiners around that. An intake/airbox upgrade is probably in order too, for various reasons. If anyone is interested to know, I could still make 10psi up top, with the actuator disconnected from the flapper, with pretty much the same setup. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 25/07/18 11:25 PM Share Posted 25/07/18 11:25 PM ah, yes, could be silicon haha didn't think of those Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 25/07/18 11:29 PM Share Posted 25/07/18 11:29 PM It's still early mate. Nothing a cuppa or two wont fix Link to comment Share on other sites More sharing options...
Slymeat Team Kickass Donating Members 1,926 Member For: 20y 2m 28d Gender: Male Location: Albion Park, NSW Posted 25/07/18 11:35 PM Share Posted 25/07/18 11:35 PM I had this very problem when I upgraded my turbo and tried many different things like reducing the silicon down to meet up with the factory silencer etc etc custom silicon but now I am just using a 4" flexi pipe from auto pro which does the job, you loose alot of what you gain if you don't delete the factory silencer as it is only 3" in diameter and severely restricts flow into the mouth of the turbo, I tested it with my car and it lost several pounds of boost above about 4000 rpm, was like hitting a brick wall. Link to comment Share on other sites More sharing options...
Sacer_Turbo_Actuator New Member 10 Member For: 5y 7m 25d Posted 17/09/18 08:11 AM Share Posted 17/09/18 08:11 AM Upgraded but never met with such issues. Maybe others with similar problems may help you. Link to comment Share on other sites More sharing options...
