BeerTurbo Donating Members 231 Member For: 5y 10m 19d Posted 21/07/18 03:51 AM Share Posted 21/07/18 03:51 AM Hi Guys, im building a little bit of stock reference data...from information obtained online. Hoping I can get some input to fill int he blanks where known. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 0280156123 Ba/Bf falcon NA and turbo injector, used with different fuel pressure for Na Vs Turbo. Flow rate 3 bar/min, N-heptane 213 G (Bosh site data) have seen these referenced as 306CC Na ECU Data - Breakpoint 0.00000799999997980194 High Slope 0.00752800004556775 Low Slope 0.0103099998086691 Turbo ECU Data Breakpoint 0.00000939999972615624 High Slope 0.00929140020161867 Low Slope 0.0135736996307969 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ FG has three ford PN listed. Stock Ones part number is: BG 9F593A - no other data - NA injector? FG Turbo ones are : BG 9F593B 0280156383 Fg turbo - black? Flow rate 3 bar/min, N-heptane 237.3 G (Bosh site data) - Have seen these referenced as 350 CC High Performance ones are 8R2Z 9F593CA 0280156385 / 8R29-CA (Light Blue) 0280156385 F6 turbo - Blue Flow rate 3 bar/min, N-heptane 310 G (possibly untrustworthy source not direct from Bosch) - People have mentioned them being 440 CC Typhoon injectors Have only located one stock data source, assume from the standard turbo FG variant, would like Typhoon Vs Standard data to compare and update with. Breakpoint 0.000022000000171829 High Slope 0.013150000013411 Low Slope 0.013399999588728 ~ Cheers Guys. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 9m 26d Gender: Male Location: Adelaide Posted 21/07/18 05:24 AM Share Posted 21/07/18 05:24 AM Sounds like you’re struggling with scaling injectors, spend half as much effort looking for data reference strategies vs typing up this thread and you’ll have everything you need Link to comment Share on other sites More sharing options...
BeerTurbo Donating Members 231 Member For: 5y 10m 19d Posted 21/07/18 05:36 AM Author Share Posted 21/07/18 05:36 AM 3 minutes ago, JETURBO said: Sounds like you’re struggling with scaling injectors, spend half as much effort looking for data reference strategies vs typing up this thread and you’ll have everything you need I am not - as they are standard injectors in a standard ECU doing standard things. What I struggle with is a lack of correct information, or miss leading information. Ive had one "tuner" tell me all ford injectors are the same and to get aftermarket ones. And if you read around, forums and here you find that does not appear to be the case. Im just looking for hard data, because if a Typhoon injector is 440cc and they can be found cheap AF, then im not going to buy a new set of Bosch 440's / Dekka 60Lbs. Not especially for this beer-can budget build skid sh*tbox. If it was my daily, sure id buy some ID's or something with correct data. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 9m 26d Gender: Male Location: Adelaide Posted 21/07/18 06:31 AM Share Posted 21/07/18 06:31 AM You want some FG F6 injectors then the only 42lb factory injector Available and exclusive to FG F6 310’s 2 Link to comment Share on other sites More sharing options...
apoc Member 2 Member For: 12y 2m 16d Posted 21/08/18 05:03 AM Share Posted 21/08/18 05:03 AM http://www.fordmods.com/ford-4l-and-6-cylinder-f1/na-fg-falcon-4-0l-stock-equivalent-injector-replacement-t132287.html The FG N/A injectors are Dekas, I cant find much info on them anywhere. I've got an FG here, can get more numbers off the injectors if needed. Definitely have Deka in the plastic though. Black with orange tips. Looks like 9316P00595 on the side, if that helps. 1 Link to comment Share on other sites More sharing options...
