Jacobcurtis New Member 21 Member For: 6y 11m 18d Posted 28/05/18 08:08 AM Share Posted 28/05/18 08:08 AM Hey guys how are we? I really need some help with an issue that has arisin with my 05 ba xr6t. ok so problems- Car missis on idle. When either cruising ( no matter what gear) or even holding the rev at the one point my car seems to miss fire until I push the clutch in and roll until revs drop and it kicks back in. Does not happen under heavy load. This problem only occurs ranging from the 2000rpm-2500rpm. No other rev, for some reason it is very specific hah... Now why I think it might be over fueling is because when I plug my code reader in and get it to mis it says the fuel system has an error then when it stops missing it says all clear. The cam control gaskets on the rocker cover had been leaking and sending oil into the 1st and 2nd spark plug barrel soaking the coil and plug in oil. I assumed that might have somthing to do with the misfire. Fixed that but only helped for a couple of days then issue came back. Shall Le I just bite the bullet and take it to the tuner and get him to have a look at it or does anyone happen to have and ideas without spending big money. Look forward to hearing from Yu guys! Thanks heaps fellas Link to comment Share on other sites More sharing options...
russell86c New Member 5 Member For: 6y 20d Posted 28/05/18 08:58 AM Share Posted 28/05/18 08:58 AM Funny thing mine was doing the same thing o decided to start at the cheapest option and work my way up. First thing I did was clean my air filter thinking maybe its starved of air. So cleaned the filter and put it all back together and problem solved. The thing was filthy Link to comment Share on other sites More sharing options...
Jacobcurtis New Member 21 Member For: 6y 11m 18d Posted 29/05/18 08:23 AM Author Share Posted 29/05/18 08:23 AM Thanks for yur reply mate, I put a k&n panel filter in there bout 3 months ago so it’s pretty clean, could do with a clean but it’s not bad.. UPADATE: I forgot to add my car is running really rich, Constantly pumping crap ton of black smoke out the exhaust.. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,116 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 29/05/18 08:53 AM Share Posted 29/05/18 08:53 AM Replace your o2 sensor. Mine was buggered and would gradually richen up until it was missing. I swapped it and it came good. Link to comment Share on other sites More sharing options...
