k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 21/05/18 12:15 PM Share Posted 21/05/18 12:15 PM Basically run it as low as possible and take it to the tuner with a jerry can or two full of E85, who will then drain your tank and put the E85 in for tuning. 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 22d Gender: Male Location: South Australia Posted 21/05/18 12:30 PM Share Posted 21/05/18 12:30 PM Keefy got it sorted. Your car won't run on ethanol unless tuned for it. When you go to the dyno, you'll want a fresh and full tank of whatever juice you're using. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 24d Gender: Male Location: Perth Posted 21/05/18 04:16 PM Share Posted 21/05/18 04:16 PM (edited) 6 hours ago, Puffwagon said: I'd recommend buying a couple of fuel filters as they will block up pretty quickly when you first switch over to e85. The first one may need changing within a week. They should be easy to blow through and if not, turf it. My third new filter is right as rain. I fitted KPM 10 micron stainless. Cleaned after 2000ks of E85. Clean as. I assumed it would be full of crap. That being said my car only has done 42k I dont recommend using the paper filter, the E85 breaks down the glue. Maybe install a brand you stock filter and after 500ks change to a stainless mesh Read the threads. All the serious E85 guys run 10 micron stainless mesh cleanable filters. I use 20L/100 cruising around and 30-40/100 when on the gas Edited 21/05/18 04:19 PM by arronm Link to comment Share on other sites More sharing options...
ToddyG6E Donating Members 33 Member For: 6y 1m 17d Posted 29/05/18 01:36 AM Author Share Posted 29/05/18 01:36 AM Hey fellas, quick update. Picked up car on saturday from the tuner, and its fu#kn awesome!!!! Drives like a big luxury jet now. So much more power and torque. Achieved 311rwkw. So when I finally work out how to do these bloody pics, ill post up the dyno sheet and a video if I can. Have tried imgur and flikr and similar sites, but bloody hopeless at tech sh*t and cant work it out. Link to comment Share on other sites More sharing options...
Typhoon Member 564 Member For: 19y 6m 28d Gender: Male Posted 29/05/18 03:27 AM Share Posted 29/05/18 03:27 AM (edited) Ryco fuel filters for the turbo Falcon are E85 suitable. Cheap and easy. google it for more info Edited 29/05/18 03:29 AM by Typhoon 1 Link to comment Share on other sites More sharing options...
Sacer_Turbo_Actuator New Member 10 Member For: 5y 7m 20d Posted 14/09/18 08:13 AM Share Posted 14/09/18 08:13 AM It 's hard to fit a turbo actuator in. Another thing, buying a actuator is not that costly. Link to comment Share on other sites More sharing options...
