_RobynKennedy New Member 4 Member For: 5y 11m 12d Posted 12/05/18 11:06 AM Share Posted 12/05/18 11:06 AM BA ICC Unit issue, Stereo dropped out and aircon whilst driving and won't turn on or work when manually try to turn on ICC,blank screen and still no fan or aircon....Things to check or anything suggested to rectify the problem? 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 12/05/18 11:08 AM Share Posted 12/05/18 11:08 AM do you get audio with the blank screen? any action when you press the buttons? Link to comment Share on other sites More sharing options...
carl.hollway New Member 3 Member For: 5y 11m 18d Posted 13/05/18 07:16 AM Share Posted 13/05/18 07:16 AM BA ICC Unit issue, Stereo dropped out and aircon whilst driving and won't turn on or work when manually try to turn on ICC,blank screen and still no fan or aircon.... Things to check or anything suggested to rectify the problem?The Fans are still working in my BABut the Stereo isn't. I have looked at all the fuses. Did you try your fuses? Link to comment Share on other sites More sharing options...
_RobynKennedy New Member 4 Member For: 5y 11m 12d Posted 13/05/18 07:32 AM Author Share Posted 13/05/18 07:32 AM Yeah I did they're 15A and all good, apparently reverse lamp fuse can be a problem as they are on the same circuit but both mine were okay worth checking your reverse lamp fuse I'd say? I ended up banging it left hand side of the steering wheel where leather meets side of ICC and banged it a couple of times and it came through was so stoked hahaha. Try that and if that doesn't work my friend told me the white plug behind ICC might be slightly unplugged or something might be worth a go? Careful with that dash triangle though man they break so easily go from right hand side top corner of it unclip that clip and then run hands along it and there's another clip on the left side otherwise you'll be in for a new one they break extremely easily not an overly complicated unit to remove but watch a youtube video on someone else doing it always helps me. Also heard can be related to ignition barrel issues which is a c**nt of a job, excuse my french! On 5/12/2018 at 9:08 PM, k31th said: do you get audio with the blank screen? any action when you press the buttons? No audio my friend and no reaction when I pressed any of the buttons mines come good for now must be an underlying issue though but my bush mechanic mate always said "if it's not broke don't fix it" so I think I'll follow his advice for now heard it can lead to car not running at all though scary stuff! 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 13/05/18 07:40 AM Share Posted 13/05/18 07:40 AM well, the BEM is in the ICC unit (at the top), which is the controller of the entire body electronics, so yeah, it needs to be connected to be working. For now, make sure the IIC itself is completely pushed in as the connector is right at the middle/back area of the ICC itself. Link to comment Share on other sites More sharing options...
carl.hollway New Member 3 Member For: 5y 11m 18d Posted 13/05/18 07:42 AM Share Posted 13/05/18 07:42 AM Yeah I did they're 15A and all good, apparently reverse lamp fuse can be a problem as they are on the same circuit but both mine were okay worth checking your reverse lamp fuse I'd say? I ended up banging it left hand side of the steering wheel where leather meets side of ICC and banged it a couple of times and it came through was so stoked hahaha. Try that and if that doesn't work my friend told me the white plug behind ICC might be slightly unplugged or something might be worth a go? Careful with that dash triangle though man they break so easily go from right hand side top corner of it unclip that clip and then run hands along it and there's another clip on the left side otherwise you'll be in for a new one they break extremely easily not an overly complicated unit to remove but watch a youtube video on someone else doing it always helps me. Also heard can be related to ignition barrel issues which is a c**nt of a job, excuse my french!Thanks for these ideas mate, I will have a look those. Link to comment Share on other sites More sharing options...
_RobynKennedy New Member 4 Member For: 5y 11m 12d Posted 13/05/18 07:44 AM Author Share Posted 13/05/18 07:44 AM 13 minutes ago, k31th said: well, the BEM is in the ICC unit (at the top), which is the controller of the entire body electronics, so yeah, it needs to be connected to be working. For now, make sure the IIC itself is completely pushed in as the connector is right at the middle/back area of the ICC itself. Yeah dude if you read my reply to carl.hollway ended up giving it a punch and she's good for now, Thankyou though for your help no doubt other people have had or will have this issue and this thread will be of help so cheers! Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 13/05/18 07:45 AM Share Posted 13/05/18 07:45 AM Yep, so that's probably the issue. Slightly out of position for the connector. Link to comment Share on other sites More sharing options...
carl.hollway New Member 3 Member For: 5y 11m 18d Posted 14/05/18 12:25 AM Share Posted 14/05/18 12:25 AM Yeah the last guy who owned it must have bumped it when he was repurbing the interior. I will have to check this outThanks Guys Link to comment Share on other sites More sharing options...
Chippey New Member 0 Member For: 4y 11m 19d Posted 05/05/19 10:08 AM Share Posted 05/05/19 10:08 AM Have a 2003 ba ICC unit turned off while driving nothing working not first time but normally a couple of hits to the the left hand side of steering wheel works , so I pulled the ICC unit out to check dim plug put back in now car may or may not start when it does no rev counter, no temp gauge, some dash lights stay on after started fuel light, oil light , engine light , any ideas of what may be causing this? Link to comment Share on other sites More sharing options...
