MUZz1984@ New Member 22 Member For: 6y 10d Posted 05/05/18 04:34 AM Share Posted 05/05/18 04:34 AM Hi can someone tell me exactly how to install amp in fg ute... Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 05/05/18 06:43 AM Share Posted 05/05/18 06:43 AM find a spot that has enough space for the amp itself and it's connections, use self tapping screws or drill pilot holes in mounting surface and mount it. Run wires from outlet of amp to relevant speakers that you wish to be "driven" by the amplifier. Run wire with fuse from positive on battery to positive on amp. Splice wire into a voltage source for when the audio unit is powered on for the "remote" connection on the amp. Run a negative wire from the negative on the amp to any chassis connection bolt nearby the amp and make sure to sandpaper the surface so that there's bare metal connection to the wiring. Install a line convertor on the audio output wires then run wires to the "input" of the amp or install the wires straight into the amp if it supports that sort of connection. Link to comment Share on other sites More sharing options...
