polishboi.luke Member 89 Member For: 9y 4m 7d Gender: Male Location: Perth w.a Posted 13/04/18 04:07 PM Share Posted 13/04/18 04:07 PM heya guys thought id do an update on my build as its going. so I ended up going 6 speed manual. conversion was very very easy. wiring was easy (I have reverse lights) only problem I came across was the centre bearing OD being different. anyways long story short I ended up getting a yellow sticker so in the process of getting this back on the road. vehicle is getting a few changes to comply and be registered and also for extra power after registering. Full spool is coming out and am replacing with a Harrop Truetrac. standard tailshaft will be removed and will be upgrading to a DBS custom tailshaft. 1.00AR rear housing will be getting replaced with a 1.15AR housing(due to rear housing causing restriction on last tune) Brakes are being changed to be more suitable for the power. picking up a set of Brembo 6 Piston front calipers with 355mm front discs and Brembo 4 Piston rear calipers with 330mm discs. once reregistered going to be doing the last tune for this setup. aiming for low 900rwhp at around 30psi. this will be the last tune on this vehicle as injectors only have another 15-20% left. also a few old suspension bushes will be replaced to improve handling. 2002 Ba XR6 Turbo 320rwkw @16psi (old tune) 437rwkw @22psi 1263nm of torque BTR 4 Speed Auto 590rwkw @ 25psi current tune T56 T56 Manual out of BF Xtreme Button twin plate Malwood Short Shifter Malwood Heavy Duty Alloy clutch master cylinder Malwood Braided clutch hose CrowCam Heavy Duty Valve Springs and Retainers Mahle Forged Pistons (20" Oversize) Scat Forged H beam Rods Billet Oil Pump gears ACL Race series bearings MLSR Head Gasket ARP Head Studs Precision 6766 1.00AR (1.15AR coming soon) 6Boost Hightmount Manifold Bosch 1600ccc Injectors Plazmaman 044 Twin Surge Tank Plazmaman Fuel Rail Turbosmart 2000 Fuel Pressure regulator Plazmaman Plenum Custom intercooler piping Turbo Smart 50mm External Wastegate 6Boost High mount manifold Freshly setup head including new valve steam oil seals, valve guides etc Battery relocation to rear Plazmaman 1200hp tube and fin intercooler Plazmaman full intercooler piping Plazmaman cold air intake 52mm Heavy Duty Alloy Radiator Custom Dump pipe Xforce 3.5inch hiflow cat stainless Xforce 3.5inch cat back stainless Walbro intake fuel pump Sct x3 flash tuner Whiteline 30mm adjustable sway bar with adjustable links Whiteline 22mm adjustable sway bar with adjustable links Xzy super sport coilovers Nolathane differential bushes 4.11 Diff Gears Fullspool diff center(removed now Harrop truetrac Protex street slotted and cross drilled front rotors(replaced with Brembo 6 piston front calipers 355mm slotted rotors) Protex street slotted and cross drilled rear rotors(replaced with Brembo 4 piston rear calipers 330mm slotted and x drilled rotors) Trw pads all round(going QFM with new Brembo Setup King wheel evolve 20x8.5 front 20x10 rear 225x35x20 front 275x35x20 rear 20% window tint Dewinged 8000k hid kit Alpine cda137ebt head unit Alpine mrf600 4 channel Alpine mrx m240 monoblock 2 x Rockford Fosgate T2D212 Soundstream 40 FARAD capacitor Sound stream ported box Stinger 0 gauge wiring Rockford fosgate T3169S Rockford fosgate T169 6 Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 9m 27d Gender: Male Location: Adelaide Posted 13/04/18 09:37 PM Share Posted 13/04/18 09:37 PM (edited) No doubt about it she’s one modified BA , what ring gap did you go with ? Edited 13/04/18 09:38 PM by JETURBO Link to comment Share on other sites More sharing options...
polishboi.luke Member 89 Member For: 9y 4m 7d Gender: Male Location: Perth w.a Posted 13/04/18 10:23 PM Author Share Posted 13/04/18 10:23 PM ummm was about 38thou I think cant remember was a while ago ran the mahle spec for 15+psi been my pride and joy just on going work. bought it 8 years ago with 80k km now its done 150 but everything is pretty much new hhah Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 2d Gender: Male Location: Perth Posted 13/04/18 11:13 PM Share Posted 13/04/18 11:13 PM While you have the diff out why dont you consider a diff ratio change. For that power 3.23 would be perfect. I have 100kw less than you 3.73 and the first 3 gears are useless , just wheel spin. 4.11 would be crazy. I will be changing mine soon ( but mostly for less gear changes at race wars). Link to comment Share on other sites More sharing options...
polishboi.luke Member 89 Member For: 9y 4m 7d Gender: Male Location: Perth w.a Posted 13/04/18 11:14 PM Author Share Posted 13/04/18 11:14 PM the 4.11s arent to bad becausei run a 275 on back to be honest basically 3rd gear is a great pull gear Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 2d Gender: Male Location: Perth Posted 13/04/18 11:23 PM Share Posted 13/04/18 11:23 PM I got 285 invo and 1/2 throttle 3rd and it spins. Even in 4th it will still spin if I dont feel it in gently. Your car must be crazy. I just drive around using 1mm of throttle and keep it off boost to go to the shops...... I gather your on 98 with those 044s. Bloody noisy pumps.. glad to get rid of mine. Link to comment Share on other sites More sharing options...
HI PSI Member 1,563 Member For: 17y 10m 4d Gender: Male Location: Central Queensland Posted 13/04/18 11:45 PM Share Posted 13/04/18 11:45 PM Also do an IMS diff hat conversion also. You will thank me later... 1 Link to comment Share on other sites More sharing options...
polishboi.luke Member 89 Member For: 9y 4m 7d Gender: Male Location: Perth w.a Posted 14/04/18 06:21 AM Author Share Posted 14/04/18 06:21 AM heya mate nah runnning e85 matey. suprisingly with the 585rwhp auto it was more tailhappy then then 790 manual. I lost a fair bit of wheel torque plus its alot more linear compared to the auto so it just goes. of course it spins 3rd but it still picks up speed really quickly and it just goes straight doesnt start hooking sideways I just got these brembos on today im so happy 2 Link to comment Share on other sites More sharing options...
polishboi.luke Member 89 Member For: 9y 4m 7d Gender: Male Location: Perth w.a Posted 15/04/18 06:02 AM Author Share Posted 15/04/18 06:02 AM brakes all done truetrac next weekend :D 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,239 Member For: 15y 11m 19d Gender: Male Location: Melbourne Posted 15/04/18 06:19 AM Share Posted 15/04/18 06:19 AM very nice Link to comment Share on other sites More sharing options...
