590Rwkw Ba Xr6t Sedan
polishboi.luke
  • Member For: 9y 5m 3d
heya guys thought id do an update on my build as its going. so I ended up going 6 speed manual. conversion was very very easy. wiring was easy (I have reverse lights) only problem I came across was the centre bearing OD being different. anyways long story short I ended up getting a yellow sticker so in the process of getting this back on the road. vehicle is getting a few changes to comply and be registered and also for extra power after registering. Full spool is coming out and am replacing with a Harrop Truetrac. standard tailshaft will be removed and will be upgrading to a DBS custom tailshaft. 1.00AR rear housing will be getting replaced with a 1.15AR housing(due to rear housing causing restriction on last tune) Brakes are being changed to be more suitable for the power. picking up a set of Brembo 6 Piston front calipers with 355mm front discs and Brembo 4 Piston rear calipers with 330mm discs. once reregistered going to be doing the last tune for this setup. aiming for low 900rwhp at around 30psi. this will be the last tune on this vehicle as injectors only have another 15-20% left. also a few old suspension bushes will be replaced to improve handling.
2002 Ba XR6 Turbo
320rwkw @16psi (old tune)
437rwkw @22psi 1263nm of torque BTR 4 Speed Auto
590rwkw @ 25psi current tune T56
T56 Manual out of BF
Xtreme Button twin plate
Malwood Short Shifter
Malwood Heavy Duty Alloy clutch master cylinder
Malwood Braided clutch hose
CrowCam Heavy Duty Valve Springs and Retainers
Mahle Forged Pistons (20" Oversize)
Scat Forged H beam Rods
Billet Oil Pump gears
ACL Race series bearings
MLSR Head Gasket
ARP Head Studs
Precision 6766 1.00AR (1.15AR coming soon)
6Boost Hightmount Manifold
Bosch 1600ccc Injectors
Plazmaman 044 Twin Surge Tank
Plazmaman Fuel Rail
Turbosmart 2000 Fuel Pressure regulator
Plazmaman Plenum
Custom intercooler piping
Turbo Smart 50mm External Wastegate
6Boost High mount manifold
Freshly setup head including new valve steam oil seals, valve guides etc
Battery relocation to rear
Plazmaman 1200hp tube and fin intercooler
Plazmaman full intercooler piping
Plazmaman cold air intake
52mm Heavy Duty Alloy Radiator
Custom Dump pipe
Xforce 3.5inch hiflow cat stainless
Xforce 3.5inch cat back stainless
Walbro intake fuel pump
Sct x3 flash tuner
Whiteline 30mm adjustable sway bar with adjustable links
Whiteline 22mm adjustable sway bar with adjustable links
Xzy super sport coilovers
Nolathane differential bushes
4.11 Diff Gears
Fullspool diff center(removed now Harrop truetrac
Protex street slotted and cross drilled front rotors(replaced with Brembo 6 piston front calipers 355mm slotted rotors)
Protex street slotted and cross drilled rear rotors(replaced with Brembo 4 piston rear calipers 330mm slotted and x drilled rotors)
Trw pads all round(going QFM with new Brembo Setup
King wheel evolve 20x8.5 front 20x10 rear
225x35x20 front 275x35x20 rear
20% window tint
Dewinged
8000k hid kit
Alpine cda137ebt head unit
Alpine mrf600 4 channel
Alpine mrx m240 monoblock
2 x Rockford Fosgate T2D212
Soundstream 40 FARAD capacitor
Sound stream ported box
Stinger 0 gauge wiring
Rockford fosgate T3169S
Rockford fosgate T169
  • Like 6
  • ...JD TUNING ADELAIDE...
  • Member For: 15y 10m 25d
No doubt about it she’s one modified BA , what ring gap did you go with ?
Edited by JETURBO
ummm was about 38thou I think cant remember was a while ago ran the mahle spec for 15+psi
been my pride and joy just on going work. bought it 8 years ago with 80k km now its done 150 but everything is pretty much new hhah
  • Dropping a turd
  • Member For: 16y 5m 29d
While you have the diff out why dont you consider a diff ratio change. For that power 3.23 would be perfect.  I have 100kw less than you 3.73 and the first 3 gears are useless , just wheel spin. 4.11 would be crazy.
I will be changing mine soon ( but mostly for less gear changes at race wars).
  • Dropping a turd
I got 285 invo and 1/2 throttle 3rd and it spins. Even in 4th it will still spin if I dont feel it in gently. Your car must be crazy. I just drive around using 1mm of throttle and keep it off boost to go to the shops......
I gather your on 98 with those 044s. Bloody noisy pumps.. glad to get rid of mine.
heya mate nah runnning e85 matey. :) suprisingly with the 585rwhp auto it was more tailhappy then then 790 manual. I lost a fair bit of wheel torque plus its alot more linear compared to the auto so it just goes. of course it spins 3rd but it still picks up speed really quickly and it just goes straight doesnt start hooking sideways
  • Like 2
